BDF between Summit Edge switch and S Series Core
Andre_Brits_Kan
Contributor II
Hi community
205ceefa948b42e0a0df1d9f20f6d545_RackMultipart20180301-80904-skwr4l-BDF_Network_Diagram_inline.jpg
I am connecting a x440-g2 two to S-Series VSF bonded chassis.
The x440 will be configured with two static routes and run ECMP to load balance traffic to the OSPF cloud.
I am looking at running BDF on the x440 to remove one of the routes in the event that we loose one of the S Series chassis.
Does the S series switches support BDF?
1 REPLY 1
Harkanwaljeet_S
Hi Andre, it is BFD.
yes, S series allows to configure bfd.
Regards,
Harkanwal
