Benefit of Stacking instead of LAG?
  • 2
  • Question
  • Updated 5 months ago
  • Answered
What other benefits are there stacking instead of LAG? Suppose I have two X620 switches which one is best for using best configuration (LAG or Stack)?
Photo of Alok Shukla
Alok Shukla
  • 834 Points 500 badge 2x thumb
Posted 5 months ago
  • 2
Photo of Lutha
Lutha
  • 304 Points 250 badge 2x thumb
HI Alok
The main advantage of stacking is that you get to take several individual switches and configure them and treat them as a single logical switch instead of as several independent individuals..
Also, depending on the particular switches and their stacking technology, you may have a switch to switch connection at much higher throughput than the capacity of an access port (or trunk port) connection between switches.
if you are using lag you will have to design a loop free topology between the ports using STP or ELRP. and you will have to manage each switch individually
Hope this helps
Photo of Volker Kull
Volker Kull
  • 1,620 Points 1k badge 2x thumb
Hi !
You need the same version of software on all stack members. In case of a software update the whole stack will reboot. Using mLAG you can update both members of mLAG peers one after the other without downtime of LACP members of the switch (f.e. Servers, other switches).
If you don ́t use LACP for connected devices you can use a stack as well and save management IPs (f.e. licennsing) and have only one device for configuration.
We pefer mLAG.
br
Volker
Photo of Claudio D'Ascenzo
Claudio D'Ascenzo
  • 110 Points 100 badge 2x thumb
Hi
use MLAG if possible, the stack could be a second option.
Regards
Claudio
