Best practice on number of SSID's per AP ?
  • Question
  • Updated 3 years ago
  • Answered
Is there a best practice on the number of ssid's per AP ?   I was working with a test ssid on some AP's in a building.  Everything seemed ok while the ssid was on the AP, but after removing it from all the AP's I was testing, I pretty much had to reboot all the AP's I was working with as they stopped passing client traffic consistently.  Management wise the AP's were up and you could connect, but no traffic consistently until rebooting the AP.  Only reason I asked about the number of ssid's as that was the only thing I modified recently.
Photo of JP
JP
  • 984 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Drew C.
Drew C., Community Manager
  • 40,250 Points 20k badge 2x thumb
Hi JP, Welcome to The Hub!
Can you share with us the AP and Controller models and the software version?
Generally speaking, other than potentially being confusing to users, the number of SSIDs shouldn't affect operation of the network.
Photo of JP
JP
3825 AP, 4110 and 5210 controller.  Firmware : 09.15.07.0008
Not sure if it matters, but the problems I was having, all the AP's were on the 5210.
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,616 Points 20k badge 2x thumb
I just had to delete two SSIDs during a lab test (20 mins ago) I didn't see any issues with the clients under test on the last SSID I still had running. You should contact the GTAC, someone should be able to review your logs and configs.
Photo of JP
JP
Ok, never had an issue like this before and the only location with the problem was the one where I was adding/removing the ssid.  Willl pursure gtac.
