Best recommended radio setting
  • Question
  • Updated 3 years ago
  • Answered
  • (Edited)
Whats the best recommended radio setting for 3805i for location "INDIA", with below setting we are not getting the best of the signals, is there any recommended antenna selection when the ap is mounted on ceiling facing down....
Photo of Saiprasad Rao Rapolu
Posted 3 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,514 Points 20k badge 2x thumb
You should contact the GTAC so they can review all the settings system wide, just these settings alone may not resolve signaling problems....
www.extremenetworks.com/support/contact
Photo of Hawkins, Bruce
Hawkins, Bruce, Employee
  • 1,090 Points 1k badge 2x thumb
The following link shows how best to lay out a 5Ghz channel plan: https://gtacknowledge.extremenetworks....
Unless you have a very sparsely populated distribution of access points, you might be better off setting all the channel width settings for the 5Ghz radios to 40Mhz and all the 2.4Ghz radios to 20Mhz. Also, you should probably move to the "All Non-DFS" channel plan on the 5Ghz side. You may see performance improvements by enabling ADDBA Support and Aggregate MPDU's for your 3805 access points.
(Edited)
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Good call Bruce.  Noticed the link didn't show up....here you go.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-create-a-5GHz-WiFi-Channel-Plan
Thanks Ryan. I noticed to and edited the original posting. Not sure why it didn't post like it's shown in KCS ...
Photo of Doug Hyde
Saiprasad Rapolu, were you able to get this issue resolved?
Photo of Sai Prasad Rao Rapolu
  • 1,494 Points 1k badge 2x thumb
No not yet, made few changes, I think im stuck @ channel width setting in default AP setting , i tried everything except channel width, I left it @ AUTO , will it create any issues, if yes i'll change it to 20 on both the radios...... so that the signal will be much better....
Photo of Doug Hyde
The auto setting should work fine, if you look at the Active AP report you can tell what the ap decided on.... Example: 157+1/40/5dBm
