Best setup for QOS with Skype for Business Online
  • Question
  • Updated 1 year ago
  • Answered
Been doing research on setting up QOS for Skype for Business on Extreme XOS switches in a enterprise network. Trying to find the best route for this since it is sharing the same vlan as the data network (obviously). Any help, suggestions, or commands to set that up would be great. If it works in extreme networks.
Photo of Bobby
Bobby
  • 210 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Manny Gutierrez
Manny Gutierrez, Employee
  • 110 Points 100 badge 2x thumb
Hi Bobby,
MS has information on optimizing networks for SfB:
https://support.office.com/en-us/article/Optimizing-your-network-for-Skype-for-Business-Online-b363b...
Although a bit dated the following Extreme guide has examples for configuring QoS on EXOS switches for SfB (formerly Lync)
http://learn.extremenetworks.com/rs/extreme/images/MicrosoftLync_ExtremeNetworks_Switches-SG.pdf
Basically by default most SfB clients mark voice packets with DSCP 46  (EF -Expedited Forwarding) and video packets with DSCP 34 (AF41 Assured Forwarding).
Here is an example config that prioritizes
create qosprofile QP4
create qosprofile QP6
configure diffserv examination code-point 34 qosprofile QP4
configure diffserv examination code-point 46 qosprofile QP6
enable diffserv examination port all
Of course any other traffic that is marked with these DSCP will also be prioritized. We do have an integration with MS Skype for Business via their SDN API (On-Premise) that includes automatically prioritizing only SfB calls by dynamically creating a policy during the call. However MS is still working on the API for SfB Online. More info on the integration can be found here:
http://www.extremenetworks.com/product/skype-for-business/
- Manny
(Edited)
Photo of EtherMAN
EtherMAN, Embassador
  • 7,370 Points 5k badge 2x thumb
Reality check...Speaking as an ISP and network providor please remember all QOS markings and settings are dropped beyond your local network.  It is good to have assurances that your VOIP traffic is clean and not congested on your LAN due to the bursty nature of our the typical applications people use each day, but once it goes through your firewall and out over the internet it is grouped and handled like any other traffic.  So make sure you pay close attention to your internet connections and the gateways you are going to for SKYPE .... We run a pingplotter server specifically to be able to go back in time and see if specific hosted services changed BGP paths or increased latency or packet loss due things outside our control on the internet...
If you have factored this in then please excuse my chatter... I can tell you from experience alot of folks believe their QOS will be honored across a public internet connection between multiple carriers... It just is not so.
Thanks EtherMAN for the additional input and clarification. Referenced MS guide does hint to it by mentioning that QoS should be deployed on managed LANs/WiFi networks as well as managed WAN. But Internet traffic is Best Effort. But could change in future if Net Neutrality rules change :-)
Photo of Bobby
Bobby
Thanks everyone for the input. I saw the thing from microsoft that was limited information. I have setup QOS for Voice VLANs just not QOS for Skype for Business that is on the same network as the data. I think i might be over thinking this. We have a sonicwall and i am setting up QOS by App control. So When it comes from either the WAN or LAN it gets detected by the application. From there on setting up QOS on the switches, Create the QOS profiles then tag the Data VLans and the Wireless VLANs for QOS but i would need to specify for the the audio and video for QOS?
