BFD for connected
  • Question
  • Updated 2 years ago
  • Answered
Hi Team ,
I have a scenario as follows
Switch (port 48) ---------------------------- (port2/8) router
There are multiple MUX between switch and router.
These MUX are not in my control.
Config on switch is
configure vlan CPC_OM add ports 41-42, 48 tagged
configure vlan CPC_OM ipaddress 10.1.1.2 255.255.255.0
enable ipforwarding vlan CPC_OM
Lets say IP on router end is 10.1.1.3
1) When i bring port 48 on switch down ; the port on router stays UP (expected as MUX link is UP and fine)
2) As per my understanding ; BFD run on top of a 'client' protocol like static,bgp,ospf etc.
3) Here the link is a "connected" link . Hence I am not sure if BFD can be of any help here . Can someone please comment ?
My requirement is that when port on switch is brought down ; router should bring down interface and hence should delete 10.1.1.x route from its routing table.
I know BFD has to be done on both sides ; I wanted confirmation from extreme end if there is a possible solution to this case .
Thanks
Photo of Gaurav Madan
Gaurav Madan
  • 270 Points 250 badge 2x thumb
  • confused
Posted 2 years ago
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,458 Points 10k badge 2x thumb
BFD is used to check layer 3 (IP) connectivity. You can use it between layer 3 switches and routers, to bring down routing neighbors or next hops.
You seem to be looking for a layer 2 mechanism. CFM would be a standardized method for this, if the router supports it.
HTH,
Erik
