BFD is not working with static routes
  • Problem
  • Updated 4 years ago
Static routes are not getting removed
Photo of Tamil
Tamil
  • 132 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
What software version are you running?
Have you tried to Delete and recreate of static route and then enabling bfd protection?
Let us know the steps which you have followed.
Photo of Tamil
Tamil
We are running with 12.6.3.2 with patch 1.7 .  The BFD mechanism was working fine previously.  This upgrade has been done before 150 days. Last week one of our link got fluctuated , but the static routes associated with was not removed from the routing table. In routing table it shows the utime of static routes also 150 days instaed of one week.
Sumit Tokle, Alum
I saw that you have created the case for similar issue. We will update you shortly on this.
Sumit Tokle, Alum
For static route, the duration counter will not be reset when the bdf is down. If next hop is not reachable for the static route then bfd would remove “f” flag. “f” flag: Provided to FIB.
On Extreme switch, Static route will always present in routing table. However, we need to concentrate on f flag(FIB entry) and see if that route is actually being used for forwarding.
Swtich will not send traffic to spefic destination if there is route without “f” flag. If we create the multiple static route for same destination then only one route would have entry in FIB(f flag is presnet) and other route  doesn’t have “f” flag and entry in FIB. However, we could see the uptime for both route in routing table since the time when we configure it.
Below example shows that we have two route for 7.7.7.1 destination with gateway 5.5.5.1 and 10.1.1.1. Only one route is in FIB(with F flag) and other is not. However, we can still see the duration time for both route.
* SW1.1 # show iproute
Ori  Destination        Gateway         Mtr  Flags         VLAN       Duration
#d   2.0.0.0/8          2.2.2.1         1    U------um--f- test       0d:3h:38m:52s
#s   4.2.2.2/32         172.16.10.23    1    UG---S-um--f- mirrror    0d:0h:9m:54s
#d   5.0.0.0/8          5.5.5.1         1    U------um--f- sumit      0d:3h:38m:52s
#d   6.6.6.1/32         6.6.6.1         1    U------um--f- sumit_test 0d:1h:41m:12s
#oa  6.6.6.2/32         5.5.5.2         14   UG-D---um--f- sumit      0d:1h:21m:0s
#s   7.7.7.1/32         5.5.5.1         1    U----S-um--f- sumit      0d:2h:18m:38s
#s   7.7.7.1/32         10.1.1.1        1    U----S-um---- v1         0d:2h:18m:10s
#d   10.1.1.0/24        10.1.1.1        1    U------um--f- v1         0d:3h:38m:52s
#d   172.16.10.0/24     172.16.10.1     1    U------um--f- mirrror    0d:0h:14m:15s
#d   192.168.1.0/24     192.168.1.1     1    U------um--f- bp         0d:3h:38m:52s
However, if we configure the BFD for OSPF route then you would see the duration timer would get changes according to BFD timer. As those are the dynamic routes.
Establishing a BFD Session for OSPF Neighbor
1 OSPF discovers a neighbor.
2 If BFD for OSPF is configured, OSPF on both routers sends a request to the local BFD server to initiate a BFD neighbor session with the OSPF neighbor router.
3 The BFD neighbor session with the OSPF neighbor router is established on both sides if BFD session limit is not reached.
* SW2.1 # show iproute
#s   2.2.2.1/32         192.168.1.1     1    UG---Sbum--f- bp         0d:3h:34m:26s
#d   5.0.0.0/8          5.5.5.2         1    U------um--f- sumit      0d:3h:34m:28s
#oa  6.6.6.1/32         5.5.5.1         14   UG-D---um--f- sumit      0d:1h:16m:49s
#d   6.6.6.2/32         6.6.6.2         1    U------um--f- sumit_test 0d:1h:36m:28s
#d   10.1.1.0/24        10.1.1.20       1    U------um--f- v1         0d:3h:34m:28s
#d   192.168.1.0/24     192.168.1.2     1    U------um--f- bp         0d:3h:34m:28s
Origin(Ori): (b) BlackHole, (be) EBGP, (bg) BGP, (bi) IBGP, (bo) BOOTP,
       (ct) CBT, (d) Direct, (df) DownIF, (dv) DVMRP, (e1) ISISL1Ext,
       (e2) ISISL2Ext, (h) Hardcoded, (i) ICMP, (i1) ISISL1 (i2) ISISL2,
       (is) ISIS, (mb) MBGP, (mbe) MBGPExt, (mbi) MBGPInter, (mp) MPLS Lsp,
       (mo) MOSPF (o) OSPF, (o1) OSPFExt1, (o2) OSPFExt2,
       (oa) OSPFIntra, (oe) OSPFAsExt, (or) OSPFInter, (pd) PIM-DM, (ps) PIM-SM,
       (r) RIP, (ra) RtAdvrt, (s) Static, (sv) SLB_VIP, (un) UnKnown,
       (*) Preferred unicast route (@) Preferred multicast route,
       (#) Preferred unicast and multicast route.
Flags: (b) BFD protection requested, (B) BlackHole, (c) Compressed, (D) Dynamic,
       (f) Provided to FIB, (G) Gateway, (H) Host Route, (l) Calculated LDP LSP,
       (L) Matching LDP LSP, (m) Multicast, (p) BFD protection active, (P) LPM-routing,
       (R) Modified, (s) Static LSP, (S) Static, (t) Calculated RSVP-TE LSP,
       (T) Matching RSVP-TE LSP, (u) Unicast, (U) Up, (3) L3VPN Route.
MPLS Label: (S) Bottom of Label Stack
Mask distribution:
     1 routes at length 8           2 routes at length 24
     3 routes at length 32
Route Origin distribution:
     4 routes from Direct               1 routes from Static
     1 routes from OSPFIntra
Total number of routes = 6
Total number of compressed routes = 0
SW1.5 # show bfd session detail
Neighbor       : 5.5.5.2             Local       : 5.5.5.1
VR-Name        : VR-Default          Interface   : sumit
Session Type   : Single Hop          State       : Up
Detect Time    : 3000 ms             Age         : 760 ms
Discriminator (local/remote)    : 4 / 4
Demand Mode (local/remote)      : Off / Off
Poll (local/remote)             : Off / Off
Tx Interval (local/remote)      : 1000 / 1000 ms
Rx Interval (local/remote)      : 1000 / 1000 ms
oper Tx Interval                : 1000 ms
oper Rx Interval                : 1000 ms
Multiplier (local/remote)       : 3 / 3
Local Diag                      : 0 (No Diagnostic)
Remote Diag                     : 0 (No Diagnostic)
Authentication                  : None
Clients                         : OSPF
Uptime                          : 00 days 01 hours 35 minutes 30 seconds
Up Count                        : 1
Last Valid Packet Rx            : 09:41:26.893554
Last Packet Tx                  : 09:41:27.360201
* SW1.6 #
Photo of Tamil
Tamil
Thanks a lot for the your  expertise reply on this.
