BGP community not being sent
  • Question
  • Updated 2 years ago
  • Answered
  • (Edited)
not showing the /32 being advertise but the other /24 in seq 20 are being advertised whats missing for the /32 to be sent out ?
configure bgp add network 31.91.192.143 255.255.255.255
create access-profile blackholes  type ipaddress
configure access-profile blackholes add 10 ipaddress 31.91.192.143 /32  exact
configure route-map xo-rm add 10 permit
configure route-map xo-rm 10 add match nlri-list blackholes
configure route-map xo-rm 10 add set community  2828 : 1650
configure route-map xo-rm add 20 permit
configure route-map xo-rm 20 add match nlri-list level3-net
conf bgp neighbor 202.112.52.105 route-map-filter out xo-rm
configure bgp neighbor 202.112.52.105 send-community
show transmitted routes show all the /24 but not the /32 with the set community whats missing here ?
Photo of joseph peleg
joseph peleg
  • 150 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Manoharan, Senthil Arasan
Manoharan, Senthil Arasan, Employee
  • 340 Points 250 badge 2x thumb
Hi Joseph,
I think you pasted cisco config.
I EXOS if you want add &  send blackhole route  through BGP you need to add the blackhole route
through CLI .
Please do the below mentioned steps.
1.Add CLI "configure iproute add blackhole 10.0.0.1/32 .
2.Create a policy then add set community "2828 : 1650".
3.Mpa the policy through network command.
4.configure bgp add network 10.0.0.1/32 network-policy ext2
5.In BGP config you need to add configure bgp neighbor <ip> send-community both.
I think you missed this.
For extended community we need to mention this command or we need to add send-community extended.
By default EXOs will send standard communuity alone.
* (Engineering) X670G2-72x.256 # sh bgp neighbor 50.0.0.2 transmitted-routes detail all
Advertised Routes:
Route: 10.0.0.1/32, Active
Origin IGP, Next-Hop 50.0.0.1, MED 0
As-PATH: 1
Community: 185337458
Hope this helps.
-Senthil.M
joseph peleg
hi thank you for the answer this is extremeWare 7.2 configuration ,
1 cant add blackhole on the /32 i get an error "IP" is directly attached to local subnet (255.255.255.255)its part of the vlan
2 configure route-map xo-rm 10 add set community  2828 : 1650
3 added  the policy via "conf bgp add network 31.91.192.143/32 xo-rm  "
4
5 no BOTH is avaiable on 7.2 we got " conf bgp neighbor 202.112.52.105  send-community
only change is the mapping on number 3 , and its still not seem to be sending the /32 after soft-reset out
thanks in advanace for the help
Hello Joseph,
Can you please try this config in CLI mode.
Meanwhile I will try to get help for extreme ware configuration.
-Senthil.M
joseph peleg
whats cli mode ? and what config should i try ? what i pasted is what i have in
Hello Joseph,
Sorry for the confusion.
CLI mode is the one which you are working now.
I just confirmed these commands are older version & its updated now.
Extremeware product also goes end of life.
As per your command we need not to go for extended communities/both command.
I guess extended communities is not available in extremeware 7.0.
Can you please try with these command alone & check whether its working.
-Senthil.M
joseph peleg
hi senthil
here is the config i have already in ,what i do see is the second route-map seq is being advertised all the /24 are there but seq 10 with the /32 and the set community is not , comparing this to cisco we do miss a NULL0 route on the /32 but when trying to add blackhole iproute on the /32 i get an error that its part of the vlan , so maybe the fix is adding another type of null route on the /32 ?
configure bgp add network 38.96.190.143 255.255.255.255 xo-rm
configure bgp neighbor 207.110.52.105 send-community
create access-profile "blackholes" type ipaddress
configure access-profile "blackholes" add 10 permit ipaddress 38.96.190.143/32 exact
configure access-profile "blackholes" add 15 permit ipaddress 66.246.45.6/32 exact
thank you
I'm not sure about this config.
After adding "66.246.45.6/32" whether BGP send 38.96.190.143/32 with community to its peer.?
-Senthil.M
joseph peleg
no it doesnt ,transmitted routes shows only the /24 which are the seq 20 on the route map but not the /32 can i email the whole config for you to look at
Photo of Drew C.
Drew C., Community Manager
  • 37,350 Points 20k badge 2x thumb
ExtremeWare 7.2 is very old software.  This sounds like a limitation or bug.  Before attempting to do any troubleshooting, I would highly recommend upgrading to the latest 7.8.4 version.
What switch model is this?
joseph peleg
BD6808
Image : Extremeware  Version 7.8.1.1 [ssh] [wlan] by Release_Master on 05/23/08 10:31:31
BootROM : 8.2
joseph peleg
hi drew, now that we ruled out a bug since i am running 7.8.1.1 any other suggestion as far as config change ?
will summery only kill any /32 advertisement ?
configure bgp add aggregate-address 38.96.190.0 255.255.254.0 summary-only
configure bgp add network 38.96.190.143 255.255.255.255 route-map xo-rm
does those negate each other ?
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,552 Points 10k badge 2x thumb
I (really) don't know how ExtremeWare was working with BGP. If it was similar to current EXOS, then your aggregate-address would be the only one advertised for all matching routes. You need an active matching route in your RIB for it to work.
joseph peleg
can you show an example on the configuration i sent here on top please , want to try anything at this point ,nothing worked so far
thanks
Hi joseph,
 As stephane mentioned the /32 prefix should be active in route table.
 Then only  BGP can transmits that prefix to its peer.
 Exrtemeware is old version some of us are not familiar with it.
 This route map functionality for /32 prefix with community may not be work in your version or
 it might be a bug.(As drew mentioned)
Since this query is looping for a while we suggest you to check some older version command reference guide & Concepts guide.
This guides belongs to  higher version than extremeware.
You may get a info about your query.
I pasted the link.
https://www.extremenetworks.com/wp-content/uploads/2014/03/EXOSReference_bookmap.pdf
https://www.extremenetworks.com/wp-content/uploads/2014/03/EXOS_Concepts_Guide_15_3_2.pdf
Meanwhile you may paste the entire config I will check.
since it is very older version not sure we can get a solution.
Any we will try to resolve or to have any work around for this issue.
Please attach or paste your version command reference guide.
-Senthil.M
joseph peleg
Thank you for the reply I am sure there is something missing in the confirm that prevent it from being sent out I'll paste the whole thing shortly or you prefer me emailing it to you directly
