BGP resource failure - VR: 0x00000002
  • Question
  • Updated 4 years ago
I've seen this periodically in our BD 10K logs (version 1514b3-patch1-4) , often after an SNMP request is blocked  by ACL though the events are about 1 minute apart.   Manual doesn't seem to reveal any reason behind the error. Anyone else seen this BGP resource failure?
06/25/2014 09:56:21.53 <Warn:BGP.UpdateMgr.PauseRsrcFail> MSM-A: DC-BGP Update Manager has paused because of a resource failure.
        VR: 0x00000002
06/25/2014 09:55:52.31 <Warn:SNMP.Master.DropReqAccessDeny> MSM-A: SNMP access from source 205.134.89.66 is denied by rule MyAccessProfile. Dropping this Request.
Photo of Cavan
Cavan
  • 234 Points 100 badge 2x thumb
  • blah
Posted 4 years ago
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,362 Points 4k badge 2x thumb
Hello Cavan,
This is just a warning message.
This is turned on by default in 15.x exos versions.
show log counter bgp --will let u know the default messages turned on.
we can simply turn it off as it is just a warning message.
Coming back to your question.
Remedy for the above error is to make more memory available for BGP in the core switch.
Note:terminate sessions
Reduce the BGP table .
Photo of Cavan
Cavan
When you say "terminate sessions", do you mean there are too many BGP sessions?
Also, Is there a way to re-allocate memory on these 10K BD?
Thanks!
