black diamond unexpected reboot after io module insert
  • Problem
  • Updated 6 days ago
Hello all, i hope you can help me
we have two black diamonds after a reboot for electrical power
one of the io module failed, and an after a change for a new module
MSM-48c from MSM-48a
and after execute the the unconfigure the black diamond reboots
and after that a error shows up
Nov  7 21:53:32 172.17.202.244 NM: MSM-B has failed for the reason of "Process Failure".
Nov  7 21:53:32 172.17.202.244 DM: BACKUP NODE (MSM-B) DOWN
Nov  7 21:53:32 172.17.202.244 DM: MSM-B FAILED (0) Process Failure
Nov  7 21:53:33 172.17.202.244 DM: Slot-4 being Powered ON
please can you help me
Photo of Sebastian Rojas
Sebastian Rojas
  • 398 Points 250 badge 2x thumb
Posted 6 days ago
Photo of EtherMAN
EtherMAN, Embassador
  • 7,340 Points 5k badge 2x thumb
trying to fully understand...
you have two 8900 chassis and had a power failure causing the system to reboot.
on reboot you had a msm B fail ?  Were you already mixing two different msm's the 48c and 48a ?
Is the failed card a new one you are trying to put in and if so you need to match the types also.
What image are you running on the cards and are they matched?
Sebastian Rojas
hi EtherMAN,
yes after the reboot, one of the slot failed, so we have to change it
show after changed, the modules were different, we have to make this prodedure
https://gtacknowledge.extremenetworks.com/articles/Solution/BlackDiamond-I-O-module-in-mismatch-stat...
but after the unconfigure command
there is any other command to see what happened to this slot
apart from:
show slot
show slot 4 detail
thanks for your time and help!
(Edited)
Sebastian Rojas
hi EtherMAN
this are the logs that showed us
Photo of EtherMAN
you can see if there is a dump file
show debug system-dump  ...
run this from each msm.  GTAC will need to look at the file to see if this was hardware or software related.  If you had a spare chassis and msm you could run an extended diagnostics on the card to check any hardware issues.  You can run this on an open slot in your current chassis too but keep in mind the diagnostics locks the msm and is a bit cpu intensive so I would do it during a sceduled window just incase...
previous info about the dump https://community.extremenetworks.com/extreme/topics/show-debug-system-dump
Sebastian Rojas
thanks a lot EtherMAN,
so if the file or dump exist and if we can see it with the following command
we are not going to be able to read because is a dump and the only people who can read it is GTAC and extreme developers, so i thinks we have to scalate this problem to the GTAC to solve this.
Thanks a lot for your time and help
you are the best, Best Regards
Photo of EtherMAN
yes on dump file... yes ans no on reading file LOL... there can be some information in the dump that we normal human beings can read and understand.  there is also a memory dump that only GTAC and the guys that think in binary can decipher >>> good luck
