Blackdiamond lack of memory with BGP
  • Problem
  • Updated 1 year ago
  • Solved
Hello!
I am experiencing some issues with Blackdiamond and BGP.
I have 2 iBGP and 2 eBGP peers for IPV4 and the same for IPv6 (8 BGP peers total). From eBGP peers I receive full routing (> 600k IPv4 routes).
With this setup memory usage is very high and sometimes the switch reboots due lack of memory.
Is there any configuration to reduce memory usage, specially to rtmgr process? Or disable other processes? Or any other ideas possibly involving filtering received routes and reduce memory consumption.
Thanks in advance.
8900-G48X-xl
XOS 16.1.3.6
I've made the following config on the switch:
<pre>
configure forwarding external-tables l3-only ipv4-and-ipv6
configure iproute reserved-entries maximum slot 2
</pre>
<pre>
sh memory
System Memory Information
 MSM-A    Total DRAM (KB): 1048576
 MSM-A    System     (KB): 40152
 MSM-A    User       (KB): 918992
 MSM-A    Free       (KB): 89432
Memory Utilization Statistics
 Card Slot Process Name     Memory (KB)
 MSM-A  A   aaa              4160
 MSM-A  A   acl              3064
 MSM-A  A   bfd              2040
 MSM-A  A   bgp              372484
 MSM-A  A   brm              1876
 MSM-A  A   cfgmgr           3316
 MSM-A  A   cli              18812
 MSM-A  A   devmgr           2060
 MSM-A  A   dirser           1456
 MSM-A  A   dosprotect       1552
 MSM-A  A   dot1ag           2580
 MSM-A  A   eaps             2416
 MSM-A  A   edp              2108
 MSM-A  A   elrp             2072
 MSM-A  A   elsm             2032
 MSM-A  A   ems              3780
 MSM-A  A   epm              2604
 MSM-A  A   erps             2524
 MSM-A  A   esrp             2316
 MSM-A  A   etmon            5116
 MSM-A  A   exacl            0
 MSM-A  A   exdhcpsnoop      0
 MSM-A  A   exdos            0
 MSM-A  A   exfib            0
 MSM-A  A   exfipSnoop       0
 MSM-A  A   exosmc           0
 MSM-A  A   exosq            0
 MSM-A  A   exsflow          0
 MSM-A  A   exsnoop          0
 MSM-A  A   exsshd           1876
 MSM-A  A   exvlan           0
 MSM-A  A   fcoe             2160
 MSM-A  A   fdb              3336
 MSM-A  A   hal              54828
 MSM-A  A   hclag            2076
 MSM-A  A   idMgr            4432
 MSM-A  A   ipSecurity       2260
 MSM-A  A   ipfix            2116
 MSM-A  A   isis             2644
 MSM-A  A   lacp             2484
 MSM-A  A   lldp             2248
 MSM-A  A   mcmgr            3404
 MSM-A  A   mpls             0
 MSM-A  A   mrp              2300
 MSM-A  A   msdp             2208
 MSM-A  A   netLogin         2448
 MSM-A  A   netTools         5796
 MSM-A  A   nettx            0
 MSM-A  A   nodemgr          1624
 MSM-A  A   ntp              2040
 MSM-A  A   ospf             2908
 MSM-A  A   ospf-3           3240
 MSM-A  A   ospfv3           2876
 MSM-A  A   ospfv3-3         2952
 MSM-A  A   pim              3164
 MSM-A  A   poe              2156
 MSM-A  A   polMgr           1928
 MSM-A  A   pwmib            1592
 MSM-A  A   rip              2524
 MSM-A  A   ripng            2228
 MSM-A  A   rtmgr            265872
 MSM-A  A   snmpMaster       4260
 MSM-A  A   snmpSubagent     4912
 MSM-A  A   stp              2596
 MSM-A  A   techSupport      2164
 MSM-A  A   telnetd          2256
 MSM-A  A   tftpd            1444
 MSM-A  A   thttpd           2624
 MSM-A  A   trill            0
 MSM-A  A   twamp            1680
 MSM-A  A   upm              2216
 MSM-A  A   vlan             3700
 MSM-A  A   vmt              2712
 MSM-A  A   vrrp             2248
 MSM-A  A   vsm              2316
 MSM-A  A   xmlc             2336
 MSM-A  A   xmld             4700
</pre>
Photo of Luiz Gustavo Barros
Posted 1 year ago
Photo of Frank
Frank
  • 3,724 Points 3k badge 2x thumb
One way would be:
 configure neighbor 1.2.3.4 maximum-prefix 400000 threshold 90
(only accept 400K routes from neighbor 1.2.3.4, make a warning log entry when we get to 90%)
Another possibility is to only accept routes of a certain length - that way you don't get a million /24 entries clogging up your routes. For instance a policy "BGP-in-filter"
entry DenySmall4 {
    if {
        nlri any/16;
    } then {
        deny;
entry PermitRest {
    if {
    } then {
        permit;
can be applied via
   configure bgp neighbor 1.2.3.4 route-policy in BGP-in-filter
and should drop anything from a /16 to /24 (and you'd still receive your default-route 0.0.0.0/0)
You can use both, policy and "cutoff", btw.
After that, I'd suggest to still keep a close eye on CPU utilization (bgp process) when a neighbor dies/comes back.
   Frank
P.S.: Oh, I'm assuming you're already using route-compression ;)
Hi Frank,
Thanks for reply.
Yes, I am using route-compression, your assumption is correct!
I will do some filtering as suggested and see what happens. I was thinking in something like this to solve my problem.
