Blacklist synchronisation on wireless controller
  • Question
  • Updated 3 years ago
  • Answered
Hello,
I have a question according the client Blacklist on the wireless controller (in the GUI reachable via "AP->Mobile Stations->Whitelist/Blacklist".
Is this Blacklist synchronized between two controllers working as HA-pair?
What is to configure for synchronization?
Thank you for help
Best regards
Stephan Harrer
Photo of Stephan Harrer
Stephan Harrer
  • 162 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,880 Points 20k badge 2x thumb
Hi Stephan,
I'm not 100% sure but I think the list is synchronized to the 2nd controller.
Synchronization is configured in..
> Controller > Administration > Availability > Synchronization Options
and also in
> VNS > Global > Sync Summary - here you'd also check whether the different services/roles/VNS.. are in sync.
-Ron
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,588 Points 5k badge 2x thumb
Stephan
This is a new feature in 9.21.01 firmware, you can set it in the same location as before, I added this mac on EWC7 and it appeared on EWC8 (its availability partner.)
I created this article for reference: https://gtacknowledge.extremenetworks.com/articles/Q_A/On-the-identifi-wireless-controller-is-the-blacklist-synchronised-to-the-controllers-availability-partner
Best regards
-Gareth
(Edited)
Photo of JAGADISH PATIL
JAGADISH PATIL
  • 70 Points
how many users can be blacklisted in this option. i mean what is the max limit for this option.
The max is 768 entries for all platforms....
-Ron
JAGADISH PATIL
  • 70 Points
Your really champ.. :-)
Thanks for ur reply.
I would like to know, is it live users or max entries which we can make entry in the table.
In my case we need to add 2500 white-list users mac address in this table which would be white-listed and can be used in the network. Rest users should not get the access.
Thanks
Jagadish Patil
Nerd would hit the nail on the head :-)
It's max. entries. So you can't add 2500 MACs.
What you could do is to blacklist/whitlist a whole OUI range i.e. E4:25:E7 = Apple.
That count as a sinble entry and you block/whitelist the whole list.
If that isn't possible in your scenario you'd need to do external MAC auth to a RADIUS with the database of the client MACs.
-Ron
