Blade 1 of 2 failed in bonded S1 Chassis
  • Question
  • Updated 2 years ago
  • Answered
Will the configuration copy over to the replacement  blade  once the chassis sees the new blade. Or will I have to redo the config for the replaced blade, in a bonded situation.
Photo of Ako Singletary
Ako Singletary
  • 240 Points 100 badge 2x thumb
  • Good
Posted 2 years ago
Photo of Daniel Coughlin
Daniel Coughlin, Employee
  • 2,526 Points 2k badge 2x thumb
It is a bit more complicated when working with singe fabric systems. The bond must be
establisted first then the configuration pushed.
Please read the following article:
If you are still having trouble give us a call.
