bpdu-restrict doesn't work (PVST+) on EXOS
  • Problem
  • Updated 1 year ago
  • Solved
  • (Edited)
Hello, everybody!
I can't make port to be disabled after it receives BPDU. I've connected the port to C2960 and it is still forwarding regardless it's access or trunk port on cisco.
Please, take a look at my confs:
configure stpd V12 ports mode dot1d 3:10
configure stpd V12 ports link-type edge 3:10
configure stpd V12 ports edge-safeguard enable 3:10
configure stpd V12 ports bpdu-restrict enable 3:10
* Slot-1 sw-b119-1.87 # sh stpd v12Stpd: V12               Stp: ENABLED            Number of Ports: 2
Rapid Root Failover: Disabled
Operational Mode: 802.1W                        Default Binding Mode: PVST+
802.1Q Tag: 12
Ports: 1:53*,3:10
Participating Vlans: V12
Auto-bind Vlans: V12
Bridge Priority            : 32768
Operational Bridge Priority: 32768
BridgeID                   : 80:00:02:04:96:8b:d5:26
Designated root            : 10:00:00:04:96:83:b0:f7
RootPathCost: 1400      Root Port     : 1:53
MaxAge      : 20s       HelloTime     : 2s      ForwardDelay     : 15s
CfgBrMaxAge : 20s       CfgBrHelloTime: 2s      CfgBrForwardDelay: 15s
Topology Change Time           : 35s            Hold time        : 1s
Topology Change Detected       : FALSE          Topology Change  : FALSE
Number of Topology Changes     : 7
Time Since Last Topology Change: 60s
Topology Change initiated locally on Port 1:53
Topology Change last received on Port none from none
Backup Root               : Off         Backup Root Activated  : FALSE
Loop Protect Event Window : 180s        Loop Protect Threshold : 3
New Root Trap             : On          Topology Change Trap   : Off
Tx Hold Count             : 6
* Slot-1 sw-b119-1.88 #
* Slot-1 sw-b119-1.89 # show stpd v12 ports 3:10
Port   Mode   State      Cost  Flags     Priority Port ID Designated Bridge
3:10   802.1D FORWARDING 200000 eDee-w-G-- 128      810a    80:00:02:04:96:8b:d5:26
Total Ports: 1
 ------------------------- Flags: ----------------------------
1:                e=Enable, d=Disable
2: (Port role)    R=Root, D=Designated, A=Alternate, B=Backup, M=Master
3: (Config type)  b=broadcast, p=point-to-point, e=edge, a=auto
4: (Oper. type)   b=broadcast, p=point-to-point, e=edge
5:                p=proposing, a=agree
6: (partner mode) d = 802.1d, w = 802.1w, m = mstp
7:                i = edgeport inconsistency
8:                S = edgeport safe guard active
                  s = edgeport safe guard configured but inactive
8:                G = edgeport safe guard bpdu restrict active in 802.1w and mstp
                  g = edgeport safe guard bpdu restrict active in 802.1d
9:                B = Boundary, I = Internal
10:               r = restricted role, t = active role
* Slot-1 sw-b119-1.90 #
Could you please tell me what is wrong? I can provide all additional information required.
Many thanks in advance,
Photo of Ilya Semenov
Ilya Semenov
  • 3,622 Points 3k badge 2x thumb
Posted 1 year ago
Ilya Semenov
Well, the solution was found. Russian engineers at distributor company investigated:
You should disable/enable to activate bpdu-restrict feature in PVST+/dot1w mode.
It would be rude to share my thoughts now...
The topic could be closed.
