Bug : Netsight -> Device View -> Device Logs Repolling -> Filtering Not Honored
  • 3
  • Problem
  • Updated 2 weeks ago
  • Solved
  • (Edited)
Hi Guys,
I've been having an issue viewing the Trap Logs and Syslogs for a particular device.
If I click on Network -> Devices -> Click gray Arrow Next to a Switch to enter Device View -> Click on Device Logs.
The Syslog and Trap events are initially automatically filtered by the device I clicked on but after a syslog or trap repoll ( i believe is set to 60 seconds) that default filter is erased and I see syslog and traps for every device.
If i then manually enter a filter by source, it filters on that , but then again on the 60 second repoll gets ignored.
The same issue occurs in  Alarms and Events -> Events -> Syslog.
If you enter in a filter on a column, the filter isn't honored on the next repoll
This makes viewing the syslogs or traps through Netsight more complicated and frustrating.
Can someone take a look at this?
Verified on version: 8.1.3.65
Photo of Byron Morales
Byron Morales
  • 272 Points 250 badge 2x thumb
Posted 2 weeks ago
  • 3
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,824 Points 5k badge 2x thumb
Hi Byron.
Bugs should be reported to GTAC. https://support.extremenetworks.com
the issues with Alarms and Events -> Events should be already fixed.
Byron Morales
I'm still seeing the issue in Alarms and Events -> Events.
I'll see if I can report this as a bug through GTAC instead.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 49,972 Points 20k badge 2x thumb
I assume Pala meant the latest version - I'm running v8.1.4.40 and my Alarms&Events filtering works.
....device logs is in the state you've mentioned.
Byron Morales
Do you know if this is already marked as a known bug in GTAC? I wouldn't want to resubmit if it is.
Sorry I can't answer that one as I don't work for Extreme Networks.
https://community.extremenetworks.com/extreme/topics/extreme-embassadors-program
Byron Morales
How do you submit a bug? I tried creating a case, then it asks for a serial number and it says that product doesn't have a maintenance agreement. I put in the info for a school that is using NMS-ADV-U purchased this summer.
Seems a bit complicated to submit a bug, unless there is a different process just for bugs.
(Edited)
Yes you open a case and it's not very complicated.... you should talk to the Extreme partner that sold you XMS to check why it's not correctly in the database.
Or just call the GTAC I'm sure they are able to correct it for you.
The issue with filtering and device logs is present in very latest development version also.
I reported it to GTAC as Case Number: 01754058. if you want to be informed about the fix, you need to contact GTAC ...
Regards
Z.
Byron Morales
Thanks Z
Photo of Dudley, Jeff
Dudley, Jeff, Employee
  • 994 Points 500 badge 2x thumb
Hi Byron,
I will move this case over in your name and take ownership.
Thanks and regards
Jeff
Byron Morales
Thanks Jeff
