BUG: soft lockup - CPU#1 stuck
  • Problem
  • Updated 3 years ago
  • Solved
One X460G2-48t-10G4 switch with 15.6.1.4 took reboot due to below errors:
10/07/2015 05:39:01.88 <Warn:EPM.UnexpctRebootDtect> Booting after System Failure.
10/07/2015 05:39:01.74 <Noti:EPM.wd_warm_reset> Changing to watchdog warm reset mode
10/07/2015 05:38:09.20 <Crit:Kern.Alert> CPU 1: soft watchdog expiration warning EPC ffffffff802ade80(r4k_wait+0x20/0x40) at 12 seconds.
10/07/2015 05:38:09.20 <Crit:Kern.Alert> CPU 0: soft watchdog expiration warning EPC ffffffff802ade80(r4k_wait+0x20/0x40) at 12 seconds.
10/07/2015 05:38:04.20 <Crit:Kern.Alert> CPU 1: soft watchdog expiration warning EPC ffffffff802ade80(r4k_wait+0x20/0x40) at 7 seconds.
10/07/2015 05:38:04.20 <Crit:Kern.Alert> CPU 0: soft watchdog expiration warning EPC ffffffff802ade80(r4k_wait+0x20/0x40) at 7 seconds.
10/07/2015 05:37:59.20 <Crit:Kern.Alert> CPU 1: soft watchdog expiration warning EPC ffffffff802ade80(r4k_wait+0x20/0x40) at 2 seconds.
10/07/2015 05:37:59.20 <Crit:Kern.Alert> CPU 0: soft watchdog expiration warning EPC ffffffff802ade80(r4k_wait+0x20/0x40) at 2 seconds.
10/07/2015 04:42:39.00 <Crit:Kern.Alert> CPU 1: Kernel thread was stuck for 10.40 seconds, jiffies: 4420685096
10/07/2015 04:42:38.00 <Crit:Kern.Alert> CPU 0: Kernel thread was stuck for 8.93 seconds, jiffies: 4420684996
10/07/2015 04:42:36.10 <Crit:Kern.Alert> CPU 0: soft watchdog expiration warning EPC ffffffff802ade80(r4k_wait+0x20/0x40) at 7 seconds.
10/07/2015 04:42:35.73 <Crit:Kern.Alert> CPU 1: soft watchdog expiration warning EPC ffffffff802ade80(r4k_wait+0x20/0x40) at 7 seconds.
10/07/2015 04:42:31.10 <Crit:Kern.Alert> CPU 0: soft watchdog expiration warning EPC ffffffff802ade80(r4k_wait+0x20/0x40) at 2 seconds.
10/07/2015 04:42:30.63 <Crit:Kern.Alert> CPU 1: soft watchdog expiration warning EPC ffffffff802ade80(r4k_wait+0x20/0x40) at 2 seconds.
10/07/2015 04:20:05.05 <Erro:Kern.Error> BUG: soft lockup - CPU#1 stuck for 72s! [swapper:0]
10/07/2015 04:20:05.05 <Erro:Kern.Error> BUG: soft lockup - CPU#0 stuck for 72s! [swapper:0]
10/07/2015 04:20:05.05 <Erro:Kern.Error> BUG: soft lockup - CPU#1 stuck for 171s! [swapper:0]
10/07/2015 04:20:05.01 <Erro:Kern.Error> BUG: soft lockup - CPU#0 stuck for 171s! [swapper:0]
10/07/2015 04:01:03.00 <Crit:Kern.Alert> CPU 1: Kernel thread was stuck for 10.34 seconds, jiffies: 4420435496
10/07/2015 04:01:02.00 <Crit:Kern.Alert> CPU 0: Kernel thread was stuck for 9.00 seconds, jiffies: 4420435396
Even though the switch is up now but these errors are still reporting. Could you please help me in this regard? This switch is installed a month ago.
Photo of Harkanwaljeet Singh
Harkanwaljeet Singh
  • 764 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Bharathiraja, Suresh
Bharathiraja, Suresh, Employee
  • 3,526 Points 3k badge 2x thumb
Hi
Please create a GTAC case with below outputs for analyze this issue.
1) show tech
2) show log message nvram
Thanks,
Suresh.B
Photo of Rahmathullah, Syed Nishath
Rahmathullah, Syed Nishath, Employee
  • 486 Points 250 badge 2x thumb
Hi Harkanwaljeet SIngh,
     From the platform, logs and version of code looks like we are hitting condition explained in :
https://gtacknowledge.extremenetworks.com/articles/Solution/Stack-of-X460-G2-logs-message-BUG-soft-l...
Can you give a try with recommendation provided in resolution section of the link and see if helps ?
Thanks,
Syed Nishath
(Edited)
Photo of Alexandr P
Alexandr P, Embassador
  • 12,476 Points 10k badge 2x thumb
Hi, all!
I agree.
First of all - you have to try another version EXOS (better upgrade from BootRom), try "run diag ext" and then opening case in TAC.
Thank you!
Photo of Drew C.
Drew C., Community Manager
  • 39,440 Points 20k badge 2x thumb
Hi Harkanwaljeet,
Have you been able to upgrade your switch to see if the above information has resolved the issue?
