c25 controller .pfe extension and assume that this software will perform the same on a 5210 controller with an .rue extension
  • Question
  • Updated 2 years ago
  • Answered
Wireless controller :
Is it a valid test to load software on a c25 controller .pfe extension and assume that this software will perform the same on a 5210 controller with an .rue extension
We have a customer that now wants to run all new software releases on a test network, before moving to a live enviroment . Currently they have a 2 x 5210 controllers Live, they are wanting to purchase a smaller controller possible c25 ( maybe 2 as the main units are HA ) load software and we also have a specific .php file .
My immediate reaction to this would be that this is not a valid test , though to be honest I have only upgraded two of these units ( 5210 in the past )
I look forward to your comments
I have also raised this as a TAC case.
Photo of Rod Robertson
Rod Robertson
  • 2,344 Points 2k badge 2x thumb
Posted 2 years ago
Photo of Jacob, Praveen
Jacob, Praveen, Employee
  • 1,022 Points 1k badge 2x thumb
Rod,
A C25 image will never work for a C5210 and vice versa.
Rod Robertson
Jacob , thanks for the reply .
I understand that , what I am after is if I load a version of code on the c25 ( .pfe extension ) and it all performs as expect .. ( test enviroment ) can I then load the correct verion of code on a c5210 HA with a .rue extension  ( live network ) and expect it to operate as the test unit .. or to make sure there are no issues or bugs between the 2 versions  do I need a c5210 in the test enviroment , to replicate .
So the question is , is the basic software and bugs the same for the c25 and the c5210 other than AP capacity .. oh ! and HA..
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,800 Points 5k badge 2x thumb
Rod
The firmware itself is the same although the actual image varies between hardware platforms.
The tests will have to take into account the difference in hardware capabilities, number of supported AP's/users etc.
-Gareth
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,174 Points 50k badge 2x thumb
Yes, you'd do that to test the features.
But I'd advice to either buy a C35 (same price as C25) or if the customer has the infrastructure to deploy V2110s.
-Ron
(Edited)
Rod Robertson
Ron
I will probably go for a C35 as suggested , the customer would not see a virtual machine as a like for like test ..
