C2G170 no start
  • Problem
  • Updated 1 year ago
  • Solved
  • (Edited)
Добрый день, помогите с проблемой, не загружается переключатель C2G170-24 В начале появится окно, проверку памяти и все перестает ((((кто может помочь ответить
Good day, help with the problem, do not load switch C2G170-24 at the start of the window appears, the memory check, and this all stops ((((Who can help answer
Photo of Саня ARKONEN
Саня ARKONEN
  • 110 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Nick Yakimenko
Nick Yakimenko
  • 2,404 Points 2k badge 2x thumb
Это данные из консоли? Покажите скриншот после проверки памяти
This is a data from console? Please provide a screenshot
Саня ARKONEN
And here in this position you twist and stay
Photo of Daniel Coughlin
Daniel Coughlin, Employee
  • 2,648 Points 2k badge 2x thumb
I am sorry but I dont think there is much we can do here.  If you get to the boot loader menu maybe the unit is recoverable. Below is a representation of what you should see.
Enterasys C2-Series Boot Code...
SDRAM Circuit Test of 511MB
100%
Version 02.01.51 06-08-2011
Computing MD5 Checksum of operational code...
Select an option. If no selection in 2 seconds then
operational code will start.
1 - Start operational code.
2 - Start Boot Menu.
Select (1, 2):
Саня ARKONEN
Here's just this menu and no, switch does not boot further (((
Саня ARKONEN
As I was told that the problem is in this memory, and that we need a bios
(Edited)
Nick Yakimenko
Так ви таки жалуетесь или хвастаетесь? Самое простое -- заменить всю доп.плату целиком, но для этого нужен донор.
Photo of Drew C.
Drew C., Community Manager
  • 37,364 Points 20k badge 2x thumb
Please stick to English, Nick... Google Translate does fine.
Саня ARKONEN
Maybe someone has copied the BIOS from such a switch, I think for such help you can pay
