C3/B3/C2-Series with "Excessive Interrupts Received for I2C interface" messages
  • 2
  • Article
  • Updated 4 years ago
  • (Edited)
Article ID: 13714
C3-Series, firmware and higher
B3-Series, firmware and higher
C2-Series, firmware and higher
Possible high CPU utilization ('show system utilization cpu') in the "CPLD_Status" task.
"Interrupt/polling" messages seen in the logging buffer ('show logging buffer') and current.log (5487); for example:
<160>Jan 3 11:36:02 SIM[108071544]: hwutils.c(3364) 301 %%
Excessive Interrupts Received for I2C interface for unit 2.
<160>Jan 3 11:36:02 SIM[108071544]: hwutils.c(3365) 302 %%
Switching to software polling.
<160>Jan 3 11:36:02 SIM[108071544]: hwutils.c(3366) 303 %%
<160>Jan 3 11:36:02 SIM[108071544]: hwutils.c(3367) 304 %%
The message may alternately include a reference to the specific interrupt:
<160>Dec 4 00:26:35 SIM[216517472]: hwutils.c(4397) 40 %%
Excessive Interrupts Received for Internal PS for unit 2.
<160>Dec 4 00:26:35 SIM[216517472]: hwutils.c(4398) 41 %%
<160>Jan 19 10:14:16 SIM[103760840]: hwutils.c(4311) 73 %%
Excessive Interrupts Received for Fan 2 for unit 3.
<160>Jan 19 10:14:16 SIM[103760840]: hwutils.c(4312) 74 %%
These messages can occur during run time as the system is monitoring various interrupts. Here the system has changed the interrupting device from an interrupt mode to a polling mode (periodic sampling), to prevent excessive CPU usage due to servicing low priority interrupts. These interrupts are not driven by traffic but by external devices like fans, PHYs, and power supplies. Once the messages are seen then you should not see them anymore unless a manual reset takes place and the system returns to interrupt mode.
Functions as Designed (FAD).
The system will switch back to interrupt mode following a unit reset. There is no reason to reset the unit, as everything will run as normal. It will not cause any issues.
Photo of FAQ User
FAQ User, Official Rep
  • 13,590 Points 10k badge 2x thumb
Posted 4 years ago
  • 2
There are no replies.
