C4110: Exception: snmp_mode instance has no attribute
  • Problem
  • Updated 3 years ago
  • Not a Problem
  • (Edited)
Hello,
I am able tu poll SNMP via Enterasys NMS, no problem at all. But I want to use some other software aswell.The problem: it doesn ́t work. I tried every setting, also with public/private and SNMPv2. No other client I used was able to connect at all. Everytime those complain about wrong settings.
e.g. Paessler SNMP Tester 5.2.1 with public
19.01.2016 12:58:21 (6 ms) : Device: 10.2.3.101
19.01.2016 12:58:21 (8 ms) : SNMP V2c
19.01.2016 12:58:21 (11 ms) : Uptime
19.01.2016 12:58:23 (2018 ms) : SNMP Datatype: ASN_PRIMITIVE
19.01.2016 12:58:23 (2024 ms) : -------
19.01.2016 12:58:23 (2029 ms) : DISMAN-EVENT-MIB::sysUpTimeInstance = No response (check: firewalls, routing, snmp settings of device, IPs, SNMP version, community, passwords etc) (SNMP error # -2003) ( 0 seconds )
19.01.2016 12:58:25 (4049 ms) : SNMP Datatype: ASN_PRIMITIVE
19.01.2016 12:58:25 (4055 ms) : HOST-RESOURCES-MIB::hrSystemUptime.0 = No response (check: firewalls, routing, snmp settings of device, IPs, SNMP version, community, passwords etc) (SNMP error # -2003) ( 0 seconds )
19.01.2016 12:58:25 (4061 ms) : Done
Now it did a show log login.log:
show log login.log which gives:
snmp_mode instance has no attribute 'is_admin'
Exception: snmp_mode instance has no attribute 'is_admin'. (file=/usr/lib/python2.4/site-packages/chantrysh/show.py:131 function=execute)
Exception: snmp_mode instance has no attribute 'is_admin'. (file=/usr/lib/python2.4/site-packages/chantrysh/abstract_command.py:122 function=execute)
Exception: snmp_mode instance has no attribute 'is_admin'. (file=/usr/lib/python2.4/site-packages/chantrysh/snmp_mode.py:31 function=execute_subcommand)
Exception: snmp_mode instance has no attribute 'is_admin'. (file=/usr/lib/python2.4/site-packages/chantrysh/abstract_command.py:85 function=execute_subcommand)
Exception: snmp_mode instance has no attribute 'is_admin'. (file=/usr/lib/python2.4/site-packages/chantrysh/log.py:325 function=execute)
software release is:  09.21.05.0007 |
- Does anyone know what might be go wrong?
- Is it possible to get root partition => / and look for some log files on the linux filesystem? e.g. some snmpd daeomon log?
Photo of n.n. n.n.
n.n. n.n.
  • 514 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,616 Points 20k badge 2x thumb
Those specific values on the controller return back nothing. That's probably why it was failing.
Not Supported:
hrSystemUptime OBJECT-TYPE
SYNTAX
Time Ticks
MAX-ACCESS Read Only
STATUS Current
DESCRIPTION
    The amount of time since this
    host was last
    initialized. Note that this is different from
    sysUpTime
    in the SNMPv2-MIB [RFC1907] because
    sysUpTime is the uptime of the
    network management
    portion of the system.
::= { hrSystem 1 }
The string sysUpTimeInstance was not found
