c4110 Maximum number of DHCP leases
  • Question
  • Updated 2 years ago
  • Answered
Can you please tell me what is the maximum number of DHCP leases that C4110 support?
Thanks!
Photo of Hilario Martin
Hilario Martin
  • 132 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,300 Points 2k badge 2x thumb
On my C25 it is..
Lease (seconds):default 36000 - max default
I assume it is the same on all Controller
BUT you can look under the physical topology within the Controller  to the DHCP lease timer
under the DHCP config option.
regards
Umut
Photo of Umut Aydin
Sorry the max should be 2592000s .
UMut
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,154 Points 50k badge 2x thumb
The internal DHCP server should only be used for "small" networks.
Check out this post...
https://community.extremenetworks.com/extreme/topics/is-it-possible-to-add-dhcp-options-i-e-option-4...
(Edited)
