C5210 Controller is not updating AP settings.
  • Problem
  • Updated 2 years ago
  • Not a Problem
C5210 controller: 2 controllers-Primary and a Foreign
APs are 3605/3610
Software: 09.21.10.0005
Our APs' ip address settings are not updating in the conttoller. Channel and Tx Power settings are not showing up either. I already checked; the APs are not active or need to be released from the other controller. I can find them in the Brocade data switch, we moved the APs to the wireless vlan. The switch and router are showing me correct info, but the controller is not updating the APs new settings.  How do I fix this?
I also noticed when I am adding new APs, they are showing up first in the Primary controller as "pending". The primary cont. is full, but why aren't they showing up in the Secondary(Foreign) controller first?
Photo of Laura
Laura
  • 1,490 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Joshua Puusep
Joshua Puusep
  • 2,264 Points 2k badge 2x thumb
I believe the channel and Tx Power info will only populate on the Local controller.  Make sure that your secondary controller is allowing all wireless ap's to connect by going to the AP tab>Global>Registration and selecting "Allow all Wireless APs to connect".  This setting is independent on each controller in a pair.
You should then be able to release the AP to the secondary controller and approve it if necessary, unless there is another issue at hand.
Photo of Laura
Laura
Both controllers have been able to show the channel and Tx power. Just recently, when I am adding/installing APs their settings are not showing up any more. I checked the Reg. settings. It's fine.
Photo of Sai Prasad Rao Rapolu
  • 1,494 Points 1k badge 2x thumb
Hi Joshua
You mean "Allow all Wireless APs to connect" should be enabled on both primary and secondary controller.
saiprasad
Joshua Puusep
If you have "allow all wireless AP's to connect" on both controllers, then the AP will connect to whichever one responds to it first and manual approval of the AP is not necessary.  You can use this setting to manipulate which controller new AP's connect to.    E.g.  If laura wants the new ap's to connect to the secondary controller, she would put "Allow only approved Wireless APs to connect" on the primary and "allow all wireless AP's to connect" on the secondary.
Photo of Scott Whall
Scott Whall, Employee
  • 548 Points 500 badge 2x thumb
Hi Laura - If you have not done so already, please open a case with the GTAC group for further investigation.
Without having a Tech support to review, I would make sure the Secondary appliance has the AP Topology set for AP registration.  I assume the Secondary also has the correct licenses in place to accept new APs.  When the APs are attached to the network, are they getting the correct IP for that AP subnet?
