C5210 not showing Active clients Report trought webGUI
  • Problem
  • Updated 1 year ago
  • Solved
  • (Edited)
Hello
Clients active report not showed trought GUI ( i have tried with differnt browsers) Only troguht ssh,Others reports works successful via GUI. If i restart the controller works some time but with the user active increase the report is not showed.  Any idea ?
Photo of Elena Madrigal
Elena Madrigal
  • 494 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Scott Whall
Scott Whall, Employee
  • 548 Points 500 badge 2x thumb
Elena - what firmware version are you running on the appliance?
Photo of Daniel B
Daniel B
  • 360 Points 250 badge 2x thumb
Hello Elena,
which Firmware is running on your controller?
Elena Madrigal
Hello i am running 10.21.01.0065  on C5210 controller. But with the same version on V2110 worked fine these reports.
Elena Madrigal
Any recomendation?
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,476 Points 5k badge 2x thumb
Elena
Is this the same controller as the one you discussed in another thread where you migrated from v2110?
I know you tried other browsers but did you try to clear the cache on the browsers?
-Gareth
Elena Madrigal
Restarting both controllers, works fine now. Clearing browser's cache help also to opening these reports faster. Issuse solved Thanks!
Ok thanks for letting us know Elena.
