C5/B5-Series LACP default settings
  • Article
  • Updated 5 years ago
  • (Edited)
Article ID: 13381
Products
C5-Series, all firmware
B5-Series, all firmware
Symptoms
Does not automatically form a dynamic Link Aggregation (LAG) upon ethernet cable attachment.
Cause
Link Aggregation Control Protocol (LACP) is not enabled by default on a per port basis.
On the C3, C2, B3, B2, and A2-Series products, LACP is enabled both globally and per port.
On the C5 and B5-Series, the defaults are different: enabled globally but disabled per port.
Solution
Use the 'set port lacp port <port#> enable' command to enable LACP on ports as required.
See also: 5531 and 12516.
Photo of FAQ User
FAQ User, Official Rep
  • 13,610 Points 10k badge 2x thumb
Posted 5 years ago
There are no replies.
