Calling Variable in XOS 15.X
  • Question
  • Updated 5 years ago
Create Date: Aug 23 2012 9:24AM
I am trying to set a variable to a port number (or range) and apply the variable when configuring a vlan:
set var uplink 1:48
config vlan vlan200 add port $uplink tag
I can see that the variable gets created and is correctly '1:48', however the config vlan command fails with the ^ pointing at the 'u' in uplink.
I am just using the scripting basics guide as my reference (they do this using $count to assign a vlan to a port), has the variable call changed in 15.X or am i simply doing something wrong / unsupported?
Thanks.
(from Nick_Lindhag)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
Create Date: Aug 23 2012 9:36AM
  • Make sure vlan200 is tagged
  • Put quotes around set var uplink "1:48"
  • Try referencing the variable with $(uplink) instead of $uplink. This helps when a variable has a special character in it.
Hope this helps.
(from john_padilla)
Create Date: Aug 23 2012 9:46AM
Thank you for the response, i have this working now.  My issue was very noob :(. I wrote the script to be used after we have enabled stacking but was testing on a new switch (stacking was not yet enabled).  I found this out by removing my "1:" and the command worked.
(from Nick_Lindhag)
