Can anyone tell me the range (coverage distance ) of Extreme Wireless 3825i AP ????
  • Question
  • Updated 2 years ago
  • Answered
I have checked the Datasheet of Extreme 3825i - But i cant able to find the exact distance its covers ??? I just want to know how much distance its covers (AP coverage distance)
Can any one help me in this ????
Photo of Boopathy Chandrasekar
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 42,280 Points 20k badge 2x thumb
There is no value X as it depend on the environment.
That is the reason you'd need to do a site survey to get a actual measurement result of the signal, signal to noise, connection rate.
Thanks Ronald.
But I thought, It will be 300 to 400 meter by default..!!!
Thanks for your suggestion.!!
