Can do feature spectrum analysis chart on Identifi wireless solotion?
  • Question
  • Updated 3 years ago
  • Answered
example FFT Duty, Cycle Real-Time FFT, Swept Spectrogram
Photo of Yong
Yong
  • 342 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Tony
Tony
  • 550 Points 500 badge 2x thumb
I think Cisco is the only vendor that implemented a special chipset into some APs, that can scan the "air" remotely. It's called SAgE.
If you don't have these APs then you can use a dedicated spectrum analyzer (USB-Adapter and Software)
Photo of Yong
Yong
Thanks you very much
Photo of James A
James A, Embassador
  • 7,492 Points 5k badge 2x thumb
Other vendors that use Atheros chipsets have spectrum analysis features, so it should be possible. Personally I use a Chanalzyer Pro.
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,710 Points 20k badge 2x thumb
I spoke with our Wireless Product Management Team, the system is not setup for this currently. We will open an enhancement request for you on this feature.
