Can I disable poe on a port of an x430p(POE) switch and use it for laptops?
  • Question
  • Updated 3 years ago
  • Answered
Photo of Sai Prasad Rao Rapolu
  • 1,494 Points 1k badge 2x thumb
Posted 3 years ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,574 Points 10k badge 2x thumb
If the port does not require poe you can use the "disable inline-power" command on that port and normal traffic should flow as intended. Here is an Article that explains this:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-enable-disable-inline-power-PoE-in-EXOS
(Edited)
Photo of Drew C.
Drew C., Community Manager
  • 38,610 Points 20k badge 2x thumb
You shouldn't need to disable PoE to use the port as a regular data port.  If the device doesn't signal that it requires power, the switch won't send it.
But if you want to disable it, the command is an easy one:  disable inline-power <port>
