Can I upgrade XOS from the bootrom Using USB flash drive ??
Prashanth_Kumar
Hi All,
I am trying to upgrade XOS from the bootrom using USB ( fat32 ). I am using this command < download image memorycard summit.xos >
The output is :-
(Re)start USB...
Scanning Bus for storage devices... 1 Storage Device(s) found
Unknown Command 'fatload' - try 'help'
* file: summit.xos image load failed from memorycard
Note : I am able to upgrade the XOS from the same USB flash drive while logging inside the switch but not from the BootRom. am I missing some commands or it is not possible to upgrade from bootrom using USB ??? ------help
3 REPLIES 3
Ram3
I tried in lab switch and don't think it is possible to upgrade the EXOS from BootROM using USB flash drive or memory card:
BootRom > download image ?
download: not enough arguments
usage: download image <[path]filename>
Prashanth_Kumar
Summit X460 and X440
Drew_C
Valued Contributor III
What model switch are you using?
