Can i use Extreme SFP transceiver for switch Cisco 3850 and Cisco 6807 XL???
  • Question
  • Updated 4 weeks ago
  • Answered
Our customer have two switchs Cisco 3850 and Cisco 6807 XL, they are using there modules:
- 1000BASE-SX SFP transceiver module  MMF  850nm  DOM
- 1000BASE-T SFP
- 10GBASE-SR SFP Module
They want to buy new Extreme SFP as below to replace:
- 1000BASE-SX SFP 10 Pack, Industrial Temp
MMF 220 & 550 meters, LC connector
- 10/100/1000BASE-T SFP module, CAT5 cable 100m link, RJ45-connector for Giga Bit Ethernet SFP Port, Industrial Temp
- 10 Gigabit Ethernet SFP+ module, 850nm, MMF 26-300m link, LC connector
is it OK ? can we use Extreme transceiver  for Cisco switch ?
Photo of Ha Do
Ha Do
  • 154 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Mel78, CISSP, ECE
Mel78, CISSP, ECE
  • 1,044 Points 1k badge 2x thumb
No. Not recommended. This is not Cisco forum. For lab environment its possible.
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-switches/866-cisco-switches-3rd-party-sfp...
Cisco will err-disable your port. They have EEPROM.
Ask your customer to buy Cisco SFP, if not they will not support it.
(Edited)
Photo of Ha Do
Ha Do
Thanks Wong Peng Leong for your answer !
Photo of Arturo Rodriguez
Arturo Rodriguez
  • 120 Points 100 badge 2x thumb
Can i use a transceiver SFP+ 1310nm 10Gb/s -8.2~0.5dBm -12.6dBm LC SM 10km Cisco for Extreme Siwtch, is this compatible?...Thanks for your help
