Can L2TPv3 be configured on Extreme Networks X460 switches?
  • 2
  • Question
  • Updated 2 years ago
  • Answered
Hey experts,
I would like to implement L2TPv3 feature on my X460-G2 switches, to extend my L2 network across the sites. Is it possible to configure it? If yes, then what is the CLI commands and from which SW version this feature is supported?
Photo of Przemek Dymitrowski
Posted 2 years ago
  • 2
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,486 Points 10k badge 2x thumb
Hi Przemek,
Unfortunately, EXOS does not support L2TPv3.
However, VXLAN is supported starting in 21.1, so that may be helpful in your situation.
-Brandon
(Edited)
Hi Brandon,
Thanks for the reply. The problem is, that I was looking for L2 stretching solution, that would not have to increase the size of MTU, which VXLAN is apparently doing.
