Can you preconfigure slot numbers on new switches going into an existing X450-G2 stack or do they have to be done at the time of install?
  • Question
  • Updated 3 months ago
  • Answered
I have an existing stack with 2 nodes already.  I am adding 3 additional switches to the stack.  Can I preconfigure the 3 new switches as slots 3-5 before hand or will they need to be done once they are added to the stack as this article points out:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-add-an-additional-X460-G2-switch-to...?
Thanks for any responses.
Photo of Tim O'Donnell
Tim O'Donnell
  • 200 Points 100 badge 2x thumb
Posted 3 months ago
Photo of David Coglianese
David Coglianese, Embassador
  • 6,274 Points 5k badge 2x thumb
You can configure the slots ahead of time, make sure you use the correct switch model.
Once you can configure the slot you can can configure the ports. This way when you physically install the switches you would just complete the switch swap procedure as if you were replacing a failed node.
I don't have the commands in front of me but...
configure slot
or
configure stacking slot
and a couple tabs should get you there.
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,574 Points 10k badge 2x thumb
configure stacking node-address <mac address of new switch> slot <slot#>
synchronize stacking node-address <mac address of new switch>
enable stacking node-address <mac address of new switch>
reboot node-address <mac address of new switch>
Here you go!
I concur with what David said. Make sure you have the module type correctly configured or else you will have to unconfigure the slot and start over.
(Edited)
Patrick,
I never thought about it before, but I could probably run all those commands ahead of time too.
Then at installation I would just be a matter of connecting stack cables and plugging in power. Just have to make sure to get the mac-address right :-)
Patrick Voss, Alum
It is a good thought but I believe the mac address has to be in the "show stacking" output in order to configure it. This is not my preferred method but in theory you can configure everything on the switch being added and it will add in automatically.
That sounds familiar now that you mention it. I always have my laptop with me so never saw the need to go the extra step,
