can I run multicasting on an X460 that has and advanced edge licence
  • Question
  • Updated 4 years ago
  • Answered
is it possible to configure multicast support with an advanced edge licence on a x460
Photo of rod
rod
  • 100 Points 100 badge 2x thumb
Posted 4 years ago
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
PIM-SM-Edge (limited to max of 2 active interfaces)
Sumit Tokle, Alum
You can find this information in EXOS concept guide "Feature License Requirements" chapter.
Photo of rod
rod
hi
Many Thanks for your help.
I have looked in the EXOS guide 15.4 , although it tells me that this PM-SM-EDGE is supported, I cannot find any reference to it in the configuration guide... also what do they mean by active interfaces ( vlan ?) finally I will be using dense mode, as al devices on 3 networks need access to this multicast.
Sumit Tokle, Alum
It's clearly mentioned on page # 1457 of EXOS concept guide 15.4.
Yes, active interface means vlan's.
