Cannot make iBGP peering over IPv6 across two Extreme X770 switches running 21.1.2.14
  • Problem
  • Updated 2 years ago
  • Solved
Hi Experts
I can't make an IPv6 iBGP peering up across Extreme switches, connected back to back. IPv4 peering is working fine. It appears Extreme has some recurring issues with IPv6 configuration.
I tried turning on and off BFD options, still it doesn't work. The BGP state is stuck in Active and there is no TCP connection coming up with ports (Remote Port/Local Port). Can anyone suggest if this is an OS bug or some other issue? BGP nei details below. Ping works fine across the switches.
Peer Description    :
IBGP Peer           : fe80::204:96ff:fe99:75b0   AS                  : 65139
Enabled             : Yes               OperStatus          : Up
Weight              : 1                 Shutdown-Priority   : 1024
ConnectRetry        : 120               MinAsOrig           : 5
HoldTimeCfg         : 180               KeepaliveCfg        : 60
Source Interface    : Not configured    RRClient            : No
EBGP-Multihop       : No                Remove Private AS   : No
BFD                 : Off               BFD Status          : Not Required
Capabilities Config : 4-Byte-As,route-refresh (old & new),ipv6-unicast
Policy for NLRI Type ipv4-unicast
  In Policy         : None
  Out Policy        : None
  NextHopSelf       : Disabled          Send Communities    : No
  Soft Input Recfg  : Disabled          Allow Looped AS-Path: No
Policy for NLRI Type ipv4-multicast
  In Policy         : None
  Out Policy        : None
Policy for NLRI Type ipv6-unicast
  In Policy         : None
  Out Policy        : None
Policy for NLRI Type ipv6-multicast
  In Policy         : None
  Out Policy        : None
State               : ACTIVE
FSM Down since      : Thu Dec  1 01:56:32 2016
 (Duration: 0:0:00:00)
Remote Addr         : fe80::204:96ff:fe99:75b0   Local Addr          : ::
Remote Port         : 0                 Local Port          : 0
Remote RouterId     : 0.0.0.0           Local RouterId      : 10.174.61.90
HoldTimeNegotiated  : 0                 KeepAliveNegotiated : 0
FsmTransitions      : 0
InUpdateElapsedTime : 00:00:12:32       InMsgElapsedTime    : 0:0:12:32
InUpdates           : 0                 OutUpdates (in TxQ) : 0 (0)
InTotalMsgs         : 0                 OutTotalMsgs        : 0
InRouteRefreshes    : 0                 OutRouteRefreshes   : 0
Capabilities Tx     : None
Capabilities Rx     : None
NLRI for the session:  None
Last State          : CONNECT           Last Event          : TCP_CLOSED
LastError           : 'None'
BGP Peer Statistics
  Total Peers       : 8
  EBGP Peers        : 2                 IBGP Peers          : 6
  RR Client         : 0                 EBGP Multihop       : 0
  Enabled           : 8                 Disabled            : 0
Photo of Sumanta Ghosh
Sumanta Ghosh
  • 458 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Baskar
Baskar, Employee
  • 518 Points 500 badge 2x thumb
Hi Sumanta Ghosh,
Can you please provide the Show configuration BGP output and , let me know whether are you able to ping the IPv6 peer ipaddress ?
Sumanta Ghosh
Is it due to using LLA for IPv6 having fe80:: range?
Sumanta Ghosh
Hi Baskar
I have updated the BGP configuration.
Sumanta Ghosh
Hi Baskar
Please see attached.
Sumanta Ghosh
Getting new error while enable/disable BGP nei.
"Configuration for family 0X41000002 and index 55 failed with rc 4"
Photo of Baskar
Baskar, Employee
Hi Sumanta,
By using the link local address, i am able to connect the BGP peer, please have a look and please share the full BGP configuration. so i can help on that
* X450G2-48t-10G4.17 # sh bgp neighbor
     Peer            AS         Weight State        InMsgs OutMsgs(InQ)  Up/Down
Ie-- fe80::204:96ff:fe99:e089%vlan1 1          1      ESTABLISHED  2      2     (0    ) 0:0:00:02
Photo of Baskar
Baskar, Employee
Hi Sumanta,
I think I got the issue in your configuration you must specify the
link-local address in the following format  , I have shared the sample Configuration below please have a look.
Sw2
configure bgp AS-number 1
configure bgp routerid 2.2.2.2
create bgp neighbor fe80::204:96ff:fe99:c8c2%vlan1 remote-AS-number 1
enable bgp neighbor fe80::204:96ff:fe99:c8c2%vlan1
disable bgp neighbor fe80::204:96ff:fe99:c8c2%vlan1 capability ipv4-unicast
disable bgp neighbor fe80::204:96ff:fe99:c8c2%vlan1 capability ipv4-multicast
enable bgp neighbor fe80::204:96ff:fe99:c8c2%vlan1 capability ipv6-unicast
enable bgp
Sw1:
configure bgp routerid 1.1.1.1
create bgp neighbor fe80::204:96ff:fe99:e089%vlan1 remote-AS-number 1
enable bgp neighbor fe80::204:96ff:fe99:e089%vlan1
disable bgp neighbor fe80::204:96ff:fe99:e089%vlan1 capability ipv4-unicast
disable bgp neighbor fe80::204:96ff:fe99:e089%vlan1 capability ipv4-multicast
enable bgp neighbor fe80::204:96ff:fe99:e089%vlan1 capability ipv6-unicast
enable bgp
By execute the command "show ipconfig ipv6 " you get the IPv6 prefix for the link-local address.
sh ipconfig ipv6
   Route Sharing               : Disabled
    Route Compression           : Enabled
    ICMP Redirect for Fast Path : Disabled
    Max Shared Gateways         : Current: 4  Configured: 4
    Route Sharing Hash          : CRC Lower
    Ping Protection             : Enabled for static routes   Interval: 2   Misses: 3
Interface              IPv6 Prefix                                        Flags
vlan1                  fe80::204:96ff:fe99:e089%vlan1/64             -EUfP--R-
Flags : D - Duplicate address detected on VLAN, T - Tentative address
        E - Interface enabled, U - Interface up, f - IPv6 forwarding enabled,
        i - Accept received router advertisements enabled,
        R - Send redirects enabled, r - Accept redirects enabled
        P - Prefix address
sh bgp neighbor
Ie-- fe80::204:96ff:fe99:c8c2%vlan1 1          1      ESTABLISHED  12     13    (0    ) 0:0:07:04
Flags: (d) disabled, (e) enabled, (E) external peer, (I) internal peer
       (m) EBGP multihop, (r) route reflector client
please let me know if you have any question or concern
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,782 Points 10k badge 2x thumb
Since link-local addresses (LLA) are only valid on one specific link, the interface where to use an LLA needs to specified explicitly.
Sumanta Ghosh
Hello All
Thanks for your responses. It got fixed by changing the interface IPv6 address to the below:-
"fc00::/127"
