Cant access Webui in WM3600 Wireless Controller
  • Problem
  • Updated 2 years ago
  • Solved
I am having Trouble accessing the webui using the management port. When i enter enter the address 10.1.1.100 it says to enable Java and after i enable java it starts loading and suddenly gives me a certificate error message. I tried googling and everything regarding the error but came up with nothing. Hoping to get some help. I need to access the webui asap.
Photo of Zaffry Ikram
Zaffry Ikram
  • 178 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Chad Smith
Chad Smith, Alum
  • 5,640 Points 5k badge 2x thumb
Kaffry,
Your browser seems to be blocking the java application.  Try the following solution (Method 2):
"Failed to validate certificate, the application will not be ...
More info on Java Security Issues:
https://www.java.com/en/download/help/jcp_security.xml
Zaffry Ikram
I dont have these options mentioned in my Java Settings
Zaffry Ikram
Okay Finally Found a Solution. I went ahead and Installed an Application called IEtester which lets me to change the required IE version . Thanks for the Help
