Can't delete static route - Please Help!!
  • Problem
  • Updated 3 years ago
  • Solved
  • (Edited)
We have multiple Black Diamond 10808 with ExtremeXOS version (v1514b3-patch1-4 by release-manager).  We are suddenly unable to delete static routes, as is the case below. I saw someone else had the issue before but there was no resolution. This is a critical problem for us! Does anyone know why this happening or how to fix?
# sho ipr 66.201.xx.xx/29
Ori  Destination        Gateway         Mtr  Flags               VLAN       Duration
#s   66.201.xx.xx/29   66.201.xx.xx   1    UG---S-um--f- Filbert      23d:19h:48m:8s
# conf iproute delete 66.201.xx.xx/29 66.201.xx.xx
ERROR: Cannot delete the net route (66.201.xx.xx/ with gateway(66.201.xx.xx)
Photo of Cavan
  • 234 Points 100 badge 2x thumb
  • anxious and frustrated
Posted 3 years ago
  • 4,362 Points 4k badge 2x thumb
could you try restarting the rtmgr process.
Then try to delete.
Photo of Cavan
I dont see a rtmgr process.
BD10K# restart process  class
Process of the same class
  <name>          Process name
    "bfd"           "bgp"           "dot1ag"        "eaps"
    "flowvsr"       "idMgr"         "isis"          "lldp"
    "mpls"          "netLogin"      "netTools"      "ospf"
    "snmpMaster"    "snmpSubagent"  "telnetd"       "tftpd"
    "thttpd"        "vrrp"          "xmlc"          "xmld"
Photo of Brian Mankin
Brian Mankin
  • 94 Points 75 badge 2x thumb
I may be grasping at straws but I think the 'f' flag indicates that this route is being used for forwarding.  If this route were to be removed, how will packets for 66.201.xx.xx/29 reach their destination?  Is the switch refusing to delete the static route because it doesn't have any way to route to 66.201.xx.xx/29 without this?
Just a guess.
Photo of Cavan
Thanks for the comments. We finally figured out how we could delete it after trying many things unsuccessfuly. We had to change the priority of the route, then we could delete. I have no idea why that's the case.  Here's is the command we used:
conf iproute add xx.xx.xx.xx /29 xx.xx.xx.xx 200      <-- set the priority of the route low
After modifying it to priority 200, we could delete it ! Still seems like a bug.
Photo of JeremyClarkson
  • 990 Points 500 badge 2x thumb
I had the same problem on a X440.
The static route flag was not 'U' up so wasn't getting used.
We also could not delete.
