Can't Select Wireless Upgrade Image From Extreme Management Ver 8.0.2.42
  • Question
  • Updated 11 months ago
  • Answered
  • (Edited)
Possibly something I am doing but have uploaded the firmware to as per the image below:
But when I select the the wireless controller, and go to set an image none will display, even if I tick the box for 'Show All Images' and refresh:
Any ideas?
Many thanks.
Photo of Martin Flammia
Martin Flammia
  • 5,744 Points 5k badge 2x thumb
Posted 11 months ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,306 Points 20k badge 2x thumb
Hi Martin,
it's working as designed :-)
You've uploaded the software and left it on the default directory setting which is TFTP with the default directory of /tftpboot/firmware/images/
But the controller is set to SCP with the default directory of /root/firmware/images/
That's the reason you don't see a file in the assign image window.
Delete the file and upload it again but choose SCP.
-Ron
Martin Flammia
So obvious now you show me... your a genius :)
Thanks Ron.
