Capacity planning in Extreme Management Centre 8.0.3
  • 3
  • Question
  • Updated 7 months ago
  • Answered
I have looked extensively and there does not seem to be a way to provide a report based on used/un-used ports over any period of time that used to exist in Inventory Manager.
There was youtube video posted about archives but it doesn't outline how to generate the reports.
Can someone please enlighten me
Photo of Stephanos Kaisharis
Stephanos Kaisharis
  • 226 Points 100 badge 2x thumb
Posted 10 months ago
  • 3
Photo of Steve Ballantyne
Steve Ballantyne
  • 5,692 Points 5k badge 2x thumb
I would also like to know this!
It appears that there used to be a Capacity Planning Report that you could run from Inventory Manager (the legacy Java console). But since that no longer exists - I cannot seem to find where this report ended up being moved to in the web interface?
Here is a GTAC that describes the old functionality.
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,502 Points 20k badge 2x thumb
It should be a pre-populated report under the Reports Tab.
Stephanos Kaisharis
Thank you but I dont see a reports tab in the latest version
Photo of Tom Currier
Tom Currier, Employee
  • 720 Points 500 badge 2x thumb
Reporting functionality in the Extreme Management Center requires a license other than NMS-Base.  If you don't see reports that indicates that you have an NMS-Base license and should contact sales to purchase an upgrade.
Stephanos Kaisharis
Thanks for the update
