captive portal wing 5.8.6
  • Question
  • Updated 5 months ago
  • Answered
I have setup a captive portal using the controller as the radius server, I can see the wifi and it prompts me for a username and password, I enter the details but it returns with wrong password
Not sure whats going on, is there a command to make sure the radius server is running on the controller ?
in the events I see the following
And looking at the events I seeing loads of this error for the other WIFI networks we have along with duplex mismatch errors  < but these seem to be new, I have never seen this many
Photo of Phil storey
Phil storey
  • 1,254 Points 1k badge 2x thumb
Posted 5 months ago
Photo of Andy Holden
Andy Holden, Employee
  • 1,492 Points 1k badge 2x thumb
Hi
There are a couple of thing you can check.
Did you define the RADIUS service under services on the Controller. This need to be applied.
Check that the date and time on the controller and APs are current. When setting up a CP user in the Radius server, you need to supply a start and end time.
Lastly, review the EVENT-HISTORY. you may see some errors defined.
If you are still having a problem, please open a case with SUPPORT
