Card , MSM and Backplane contention.
  • Question
  • Updated 3 years ago
  • Answered
I am trying to find out the contention rates between various modules in a BD8800
ie the difference between an 8 port 10 G card and a 24 port 10 Gig card  ( 8900-10G24X-c ) and what dependencies on the specifics MSM's
Photo of Rod Robertson
Rod Robertson
  • 2,344 Points 2k badge 2x thumb
Posted 3 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
Hi Rod,
You can find most of this information in the BlackDiamond 8800 datasheet, in Figure 2: Connectivity Options by I/O Module and Figure 4: MSM Module Options
Essentially, with two 8900-MSM128's, you can get up to 128 Gbps throughput on an 8810 chassis, and up to 80 Gbps on an 8806 chassis for both of these cards (8900-10G24X-c and 8900-10G8X-xl). The primary difference is that the XL module has larger table sizes, and will not be oversubscribed. The 8900-10G24X-c will be oversubscribed by a factor of 1.875 with two 8900-MSM128's in an 8806 chassis, and oversubscribed by a factor of 3 in an 8810 chassis.
-Brandon
Photo of EtherMAN
EtherMAN, Embassador
  • 6,456 Points 5k badge 2x thumb
Brandon doesn't the switch backplane down grade to lowest card type in the 8900 line... so an xl card will take on the -c card tables??
Rod Robertson
EtherMAN that sound logical ...
