Change IP Extreme Management Ver 8.0.2.42 not working
  • Problem
  • Updated 1 year ago
  • Solved
Have had problems changing the IP address of Netsight (V8.0.2.42), and am currently getting a connection refused, the server.log is showing the following error:
2017-07-30 12:01:35,728 ERROR [org.jboss.as.controller.management-operation] WFLYCTL0013: Operation ("add") failed - address:
NetSight is running on a VMWare, and I am able SSH on to it with the new IP.
To change the IP I ran dnetconfig from /usr/postintall/
Have run through the usual checks on the GTAC knowledge base, like looking at the
.netsight file at location /var/Extreme_networks but
JBOSS_HOSTNAME=
no longer exits, and also at the hosts file at /etc, which is showing the correct new IP address.
So I think there is something else the dnetconfig has missed updating when it was run?
Not sure if there is anything else I need to check?
Thanks in advance.
Photo of Martin Flammia
Martin Flammia
  • 6,326 Points 5k badge 2x thumb
Posted 1 year ago
Photo of Michael Butterfield
Michael Butterfield, Employee
  • 200 Points 100 badge 2x thumb
Hi Martin,
Check that the appdata/NSJBoss.properties file is updated with the new IP address for the jboss.bind.address.   If it is not, add it and restart the server.
Thanks
Mike Butterfield
Martin Flammia
Yep, that did it! Thanks Micheal.
