Change IP on interface VLAN remote
  • Question
  • Updated 3 years ago
  • Answered
Is it an easy way to change a interface VLAN remote?
As far as I see it is not possible to set more than one IP an a interface...
Photo of Nobel
Nobel
  • 282 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Tommy
Tommy
  • 342 Points 250 badge 2x thumb
Official Response
You can make a script that does it for you, something like:
unconfig default ipaddress
config default ipaddress x.x.x.x/xx
That should do it.
(Edited)
Photo of Tommy
Tommy
Official Response
Sorry should have written that too :)
You can make the script directly on the switch with the command :
edit script "script_name"
You will then use the builtin VI editor to make the script, and then you can load that script with the command :
Load script "script_name.xsf"
You can also make the script in notepad++ or what ever text editor you use, and save it as a .xsf file and upload into the switch with the command:
tftp get x.x.x.x vr vr-xx "filename.xsf"
That should get you the file onto the switch and you can again load the script as mentioned before.
(Edited)
