Changing bandwidth for AVB
  • Question
  • Updated 1 year ago
  • Answered
Dear Experts,
I have a Summit X440-24t AVB switch. I would like to know if there is a command, which could be used to change the bandwidth allocated to best effort traffic, so that it can be used by AVB.
Is the standard setting 75% for AVB and 25% fro best effort?
Thank you,
Jakub
Photo of Jakub Mielczarek
Jakub Mielczarek
  • 180 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
Hello Jakub.
Welcome to the Hub.
Yes, you are correct. AVB is using MSRP(Multiple Stream Reservation Protocol).This technology ensures audio and video can leverage a predefined amount of the bandwidth for AVB audio. This amount is 75% of the maximum data rate; the other 25% of bandwidth can be used for other data. (Note: These percentage allocations can be adjusted as required across all Extreme Networks AVB-enabled switches.)
If you used Summit x440-24, sorry you cannot configure the bandwidth.
If you had G2 product, such as, x460-G2, you could change the bandwidth by using "configure msrp ports traffic-class delta-bandwidth"
http://documentation.extremenetworks.com/exos_commands_22.2/exos_21_1/exos_commands_all/r_configure-...
Best regards,
