Changing Source Address Time-out on Switches and Bridges
  • Article
  • Updated 4 years ago
Article ID: 3460
Products
NetSight Element Manager
Symptoms
When you change 1 port on a switch/bridge to the maximum of 14400 seconds, all ports are changed to that setting.
Cause
The SAT never really flushes if set to the maximum of 14400 seconds. This could cause connection problems with your users.
Solution
There are 2 places in NetSight Element Manager where you can change this time-out. They are:
1. In Chassis Manager, click on Device on top menu bar, then Bridge Status, Then a specific port, then Source Addressing. The time-out is now available for changes.
2. In Chassis Manager, click on a specific port on the board, click on source addressing. This also allows you change the time-out.
You are also able to change this time-out by using the Mib Tools located under the Utilities menu. The location of the Mib is:
dot1dTpAgingTime located at 1.3.6.1.2.1.17.4.2
Photo of FAQ User
FAQ User, Official Rep
  • 13,610 Points 10k badge 2x thumb
Posted 4 years ago
There are no replies.
