Channel Width Multi-Edit?
  • Question
  • Updated 3 years ago
  • Answered
Does anyone have a way to change Channel Width on Radio 2 for multiple AP's?
AP Multi-Edit is grayed-out, as it appears to differ between code versions.
Thanks
Photo of Schmotter, Ryan
Schmotter, Ryan, Employee
  • 650 Points 500 badge 2x thumb
Posted 3 years ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,616 Points 20k badge 2x thumb
You will need to select the radio mode before that setting can get unlocked.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,114 Points 50k badge 2x thumb
Doug was faster, but here a screenshot...
Photo of Joseph Burnsworth
Joseph Burnsworth
  • 2,328 Points 2k badge 2x thumb
This will only work if the AP's are of the same model. if you are selecting a few 3610's, a few 3705's, and a few 3825's at the same time, this will also not allow you.
