Check the performance of an AP depending on the power it recieves
Cornel_Smit
New Contributor II
Hi Guys
Is there a way to see what performance the AP gives depending on the power it receives.
I know the 3935 will transmit on 2x2 when it only gets 15w power and 4x4 on 25w.
But is there a place to confirm it is broadcasting at that either via the Gui on the controller or the CLI of the AP.
Regards
2 REPLIES 2
Cornel_Smit
New Contributor II
Hi Sam
Thanks for that.
I completely forgot about that......
Been a long 2 weeks.
Regards
Sam
Hi Cornel,
From the home screen on the GUI you are able to view AP's that are in low power mode in the health table.
Hope this helps.
Best regards,
Sam
