Cisco 9970 IP vidoe phones are connected to X440 48p sumit switches, video not working
  • Question
  • Updated 2 years ago
  • Answered
Hello, Cisco 9970 IP phones are connected to X440 48p sumit switches, Problem is video cam will not work. but when the same phone is hooked to Cisco switch it will work. what config do we need to make on XOS that will support the video? we have LLDP config on all XOS devices but video still not working.. please assist..
Photo of Arjumand Qazi
Arjumand Qazi
  • 958 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Bastian Sprotte
Bastian Sprotte, Employee
  • 1,660 Points 1k badge 2x thumb
hello,
the Phone might require LLDP-MED options to understand that it can request more PoE power from the switch. So please try to enable the PoE MED options per LLDP.
configure lldp port 1:1 advertise system-description
configure lldp port 1:1 advertise system-capabilities
configure lldp ports 1:1 advertise vendor-specific med capabilities
configure lldp ports 1:1 advertise vendor-specific med power-via-mdi
regards
Bastian
Arjumand Qazi
hello Bastian, thanks for the feedback I am missing on
but the last 2 commands of lldp are are alreadt there, advert system-desc and advert system-capab commands will do any difference?
Arjumand Qazi
Hello,
how can I manually set in-line power in X440..
the Cisco IP 99xx series is Class 4 PoE device that may require power up to 25w, can I manually set the power setting on the port itself ?
