Clear old Entries from Netsight
  • Question
  • Updated 2 years ago
  • Answered
We had enabled Guest SSID to be seen on Netsight however we have removed the Guest SSID but we still see the old entries in Netsight.
How do we clear all these old entries, tried to delete it manually but there are 85 pages of entries around 3500 End systems
Photo of Sandeep Srinivasa
Sandeep Srinivasa
  • 312 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 49,992 Points 20k badge 2x thumb
Do you mean end-systems in ExtremeControl (NAC) ?
Could you post a screenshot or in which view you'd see all this clients.
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,834 Points 5k badge 2x thumb
If you run Nac Manager (legacy java application) then you can delete them quite easily as all of them will be on the same list.
There is also setting for how long should the inactive endsystem be in the database. You can define when will the endsystem table cleanup happen.
I am sure the setting is also available in OneView.
(Edited)
Sandeep Srinivasa
Thanks a lot I have set it to 3 days and now I dont see old records.
