clear flow and egress counters
  • Question
  • Updated 5 years ago
Create Date: Jun 5 2012 10:31AM
Hi
I have bd8810, 12.5.4.5, MSM-48c, "C" cards. I configured clear flow with ingress counters on ports to notice some peak or bursts on ports. All works ok on ingress but on egrees doesn't. There are acl with counters on ports, i see counters but clear flow dosen't see counters on egress.
configure access-list clear-flow ports 2:1 ingress
configure access-list clear-flow ports 2:1 egress
# show access-list
Vlan Name Port Policy Name Dir Rules Dyn Rules
* * qp3acl ingress 23 0
* 2:1 clear-flow ingress 2 0
* 2:1 clear-flow egress 2 0
# show access-list port 2:1 egress
#Policy Entries
1 entry_tag_1
2 entry_untag_2
3 check_port_1g_rule1
# show access-list port 2:1 ingress
#Policy Entries
1 entry_tag_1
2 entry_untag_2
19 # show access-list counter ports 2:1 egress
Policy Name Vlan Name Port Direction
Counter Name Packet Count Byte Count
clear-flow * 2:1 egress
bytecounter1 869143340
entry_tag_1 {
if match all {
ethernet-type 0x8100 ;
then {
byte-count bytecounter1 ;
entry_untag_2 {
if match all {
ethernet-type 0x0800 ;
then {
check_port_1g_rule1 {
if match all {
delta bytecounter1 >= 700000000 ;
period 8 ;
then {
snmptrap 123 "Traffic predefined_rule1 exceeds threshold" ;
syslog "one port in bytecounter port:$port vlan:$vlanName : $policyName regula: $ruleName wartosc: $ruleValue" INFO 2 ;
and output from clear flow:
# show clear-flow port 2:1
Rule Name Period Type Last Rel Threshold TCNT NumAction
Value Oper If Else
check_port_1g_rule1 8 DT 5159021 >= 700000000.000000 0 2 0
Total Entries: 1
thanks for any help
regards
Peter
(from peter_peter)
Photo of EtherNation User
EtherNation User, Employee
  • 20,340 Points 20k badge 2x thumb
Posted 5 years ago
There are no replies.
