Clear flow "delta" action
  • Question
  • Updated 4 years ago
  • Answered
  • (Edited)
Hi everybody. I have trouble again...
I'd like to create an OpenFlow rule which sends the syslog message when broadcast rate reaches 1000 pps in some VLANs. I've applied this rule to VLAN and disabled all ports on the switch. But I see those syslog messages... What's wrong with rule?
entry BCAST-PKT {
        if {
                ethernet-destination-address ff:ff:ff:ff:ff:ff;
        then {
               count bcast-pkt;
entry BCAST_flood {
        if {
                delta  bcast-pkt > 1000;
                hysteresis 100;
                period 1 ;
        then {
                syslog "Too many broadcast frames in VLAN $VlanName... Rule $ruleName exceeds limit $ruleThreshold" WARN 120;
        else {
                syslog "Broadcast frames in VLAN $VlanName falls bellow rate." WARN;
<Warn:ACL.CLEARFlow.Warning> Slot-1: Too many broadcast frames in VLAN v20... Rule BCAST_flood exceeds limit 1000.000000
<Warn:ACL.CLEARFlow.Warning> Slot-1: Too many broadcast frames in VLAN v11... Rule BCAST_flood exceeds limit 1000.000000
<Warn:ACL.CLEARFlow.Warning> Slot-1: Too many broadcast frames in VLAN v22... Rule BCAST_flood exceeds limit 1000.000000
<Warn:ACL.CLEARFlow.Warning> Slot-1: Too many broadcast frames in VLAN v31... Rule BCAST_flood exceeds limit 1000.000000
<Warn:ACL.CLEARFlow.Warning> Slot-1: Broadcast frames in VLAN v20 falls bellow rate.
<Warn:ACL.CLEARFlow.Warning> Slot-1: Broadcast frames in VLAN v11 falls bellow rate.
<Warn:ACL.CLEARFlow.Warning> Slot-1: Broadcast frames in VLAN v22 falls bellow rate.<Warn:ACL.CLEARFlow.Warning> Slot-1: Broadcast frames in VLAN v31 falls bellow rate.
Photo of eyeV
eyeV
  • 2,484 Points 2k badge 2x thumb
Posted 4 years ago
Photo of Sumit Tokle
Sumit Tokle, Alum
  • 5,738 Points 5k badge 2x thumb
I haven't seen any log in my test switch as shown below,
B3U36.13 # show policy test
Policies at Policy Server:
Policy: test
entry BCAST-PKT {
if match all {
    ethernet-destination-address ff:ff:ff:ff:ff:ff ;
then {
    count bcast-pkt ;
entry BCAST_flood {
if match all {
    delta bcast-pkt > 1000 ;
    hysteresis 100 ;
    period 1 ;
then {
    syslog "Too many broadcast frames in VLAN $VlanName... Rule $ruleName exceeds limit $ruleThreshold" WARN 120 ;
else {
    syslog "Broadcast frames in VLAN $VlanName falls bellow rate." WARN ;
Number of clients bound to policy: 1
Client: acl bound once
* B3U36.14 #
B3U36.14 # show log
No log messages were displayed.
* B3U36.15 #
B3U36.15 # show access-list counter
Policy Name       Vlan Name        Port   Direction
    Counter Name                   Packet Count         Byte Count
test              Default          *      ingress
    bcast-pkt                      0
* B3U36.16 #
Did you apply the policy on port or on VLAN?
DId you see the ACL counters are keeps on increasing?
If there are less number of ports in vlan then try to apply the policy per port basis and try to narrow down the issue.
Photo of eyeV
eyeV
Thank you. This is really weird.
I applied this policy on some VLAN.
No, the ACL counters doesn't increase.
Ok. I'll try to apply this policy on ports and add matching condition vlan-id.
Sumit Tokle, Alum
* B3U36.6 # show access-listVlan Name    Port   Policy Name          Dir      Rules  Dyn Rules
Default      *      test                 ingress  1      0
* B3U36.7 #
I have applied the policy on vlan too.
Photo of eyeV
eyeV
It seems I was a bit obvious. I haven't seen any log messages too when all ports are disabled. Maybe I didn't quite understand the Concepts Guide, because...
I have simple config. Vlan 21 added untagged to port 1:1 and tagged to port 1:25. Port 1:25 is active.
I have the same policy file, but I've deleted "hysteresis 100" statement.
show policy "block-in-abonvlan"
Policy: block-in-abonvlan
entry BCAST-PKT {
if match all {
then {
    count bcast-pkt ;
entry BCAST_flood {
if match all {
    period 1 ;
then {
else {
show access-list
v21          *      block-in-abonvlan    ingress  1      0
show ports 1:25 vlan statistics no-refresh
Port    Vlan      Rx Frames          Rx Byte         Tx Frame        Tx Byte
                        Count          Count            Count          Count
xCore        v21        112           14289                0                0
05/24/2014 12:17:29.79 <Warn:ACL.CLEARFlow.Warning> Slot-1: Too many broadcast frames in VLAN v21... Rule BCAST_flood exceeds limit 1000.000000
05/24/2014 12:17:30.81 <Warn:ACL.CLEARFlow.Warning> Slot-1: Broadcast frames in VLAN v21 falls bellow rate.
xCore        v21        200           25287                0                0
block-in-abonvlan v21              *      ingress
    bcast-pkt                      1096
05/24/2014 12:32:59.66 <Warn:ACL.CLEARFlow.Warning> Slot-1: Too many broadcast frames in VLAN v21... Rule BCAST_flood exceeds limit 1000.000000
05/24/2014 12:33:00.69 <Warn:ACL.CLEARFlow.Warning> Slot-1: Broadcast frames in VLAN v21 falls bellow rate.
    bcast-pkt                      1150
If I have not misunderstood the Concepts Guide my policy should trigger when broadcasts frames in VLAN 21 will increase by 1000 per second. Is it right?
I'm sorry about my English. It's not my native language. I always make a lot of mistakes actualy.
Photo of eyeV
eyeV
I've changed policy again
entry BCAST-PKT {
if match all {
then {
    count bcast-pkt ;
entry BCAST_flood {
if match all {
    delta bcast-pkt > 20 ;
    period 10 ;
then {
    syslog "$RuleValue Too many broadcast frames in VLAN $VlanName... Rule $ruleName exceeds limit $ruleThreshold" WARN 30 ;
else {
And it seems that rule works correct. Can I set the value of 1 second for the period?
Sumit Tokle, Alum
It's depends on how much traffic you are expecting.
Photo of eyeV
eyeV
Hello everybody.
TAC has opened a "CR" about my problem. I have an ID of this CR. Unfortunately, it's still open.
Photo of Drew C.
Drew C., Community Manager
  • 39,376 Points 20k badge 2x thumb
What's the CR number?  I'll look it up for you.
Photo of eyeV
eyeV
It would be great. The CR number is xos0057835.
Photo of Drew C.
Right now that CR shows that it is assigned to an engineer to be fixed, but hasn't been built into a release version of EXOS yet.
Photo of eyeV
eyeV
Thanks for making it clear, Drew.
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
It might be fixed in the monthly release
Photo of eyeV
eyeV
Hope so. Thank you Parthiban.
